b7100 3 pt hitch stop?
   / b7100 3 pt hitch stop? #1
catch2nd
So I am building a weight box for my 3pt hitch to counter act the snowblower.
My concern is that when the hitch is all the way down is seems like it spongy, not a solid stopping point, and that all the weight sitting on it like that could break something.
Is this normal, should I just chain is up?
Dustin
   / b7100 3 pt hitch stop? #2
You may consider setting it up so the three point is raised to hold up the box. When parked lower it to the ground.:D
   / b7100 3 pt hitch stop? #3
I just have a small stack of 2x pieces that serve the purpose of holding the weight of the 3ph ballast when the tractor is parked in the garage. I don't know if it helps the tractor but it sure makes me feel better that I don't have the 400-600lbs hanging on the back for no reason.
yeah, my thoughts also
thanks for the ideas guys!
   / b7100 3 pt hitch stop? #5
What kind of snowblower do you run? I've got a B748 and don't have any weight issues.
2016 Case 821F Articulated Wheel Loader (A54811)
2016 Case 821F...
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A55218)
2012 Ford F-150...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
2017 Caterpillar 326FL Hydraulic Excavator (A53421)
2017 Caterpillar...
76in Fork Extensions (A52378)
76in Fork...
11ft S/A Fuel Tank Trailer Frame (A51691)
11ft S/A Fuel Tank...
