B6200 - Doesn't Shut Off with key
   / B6200 - Doesn't Shut Off with key #1
beartoothweb
Montana
Just picked up an older B6200 with FEL, mower, and aerator. Needs paint, but low hours, and it runs well.
The guy dropped it off for me yesterday, a great guy, and when I went to tool around the yard a bit after he left, I couldn't get it to shut down with the key. I had to pull the throttle back by hand to stall it and kill it that way.
Am I doing something wrong? Is there a secret to shutting it down, or do I need to look at the wiring? Didn't want to get into it if it was something simple.
   / B6200 - Doesn't Shut Off with key #2
Don't worry about the key. After it's running take it out and put it in your pocket.
Pulling back on the throttle is the correct way to stop it!:thumbsup:
   / B6200 - Doesn't Shut Off with key #3
What??????????????
   / B6200 - Doesn't Shut Off with key #4
If you are talking about the red knob on the lower right of the dash that you pulled on. It's the fuel shut off and is the only, well proper way to shut it off. The black knob on the left is a manual decompression for starting in cold weather. Glad you figured it out. I have seen postings on here before where people are asking for help while the tractor is still running trying to figure it out.:thumbsup:
Cool, good to know, I figured it was something like that. I'm a gear head, but all hot rods and stuff that runs on GAS, this is my first diesel, so I was a little worried about messing with the fuel cut off, etc.
Should be a fun little tractor!
   / B6200 - Doesn't Shut Off with key #6
Boy, did I get my Feet into it. The method I described was for My B7100 HST.:ashamed::ashamed:
Agway AccumuL8 Grabber (A50515)
Agway AccumuL8...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
Polecat swift 206R (A50322)
Polecat swift 206R...
2015 CIMC 40FT CONTAINER CHASSIS (A52141)
2015 CIMC 40FT...
2012 Ford F-250 Crew Cab Pickup Truck (A50323)
2012 Ford F-250...
Case Ih 2388 Combine (A50514)
Case Ih 2388...
