b5100e can find the dip stick
   / b5100e can find the dip stick #1
agape woodworker
Lancaster PA
I just got a b5100e and checking all the fluids. And I came to the transmission fluid and cannot find the dipstick or sight glass. Can some one help me? I think that it is low because the 3 pt hitch goes up but acts like its got air in it.
   / b5100e can find the dip stick #2
If your b5100 is like my b7100 the dipstick is just to the right of the shift lever on the top of the transmission.
   / b5100e can find the dip stick #5
But I don't think the transmission oil operates the 3 point lift. I had the same issue with my B5100E and scoured the shop manual (still available in photocopies from the dealer). The transmission dipstick is indeed as described, but there is no mention of the fill plug for the lift. Look behind the seat, a bit to the right and there is a classic looking fill plug. I filled that with hydraulic fluid and the lift works better now. Good luck
   / b5100e can find the dip stick #6
I had a B5100E...Wish I would have kept it and the manuals for it...Good luck and you're going to like that little bullet proof tractor.
Don
   / b5100e can find the dip stick #7
Whap! That's for thinking with your dipstick, Laddie!
(sorry - couldn't help myself)
   / b5100e can find the dip stick #8
The dipstick on the B5100 I had been replaced with a screw on cap when I bought it. However there was screw in plug or bolt on the right side. That you could remove and if the fluid started to ooze out it was full.
I miss the sound of that little tractor.
   / b5100e can find the dip stick #9
I was completely wrong in my earlier reply. The shop manual has one small line in the transmission section stating that the hydraulics work from the transmission oil.
Oh well, it was probably time to change the transmission oil anyway and now that I've mixed in hydraulic fluid it will happen.
Sorry about the misinformation earlier.
2018 CASE IH 110N LOT NUMBER 223 (A53084)
2018 CASE IH 110N...
Ford Stakebody Truck (A52377)
Ford Stakebody...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2015 Jeep Wrangler Multipurpose Vehicle (MPV), VIN # 1C4BJWEG5FL757630 (A51572)
2015 Jeep Wrangler...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
