B5100 Loader?
/ B5100 Loader? #1
whome
I realize a B5100 is kind of small but can these tractors be equipped with a front end loader? Thanks for any input.
/ B5100 Loader? #2
B5100 loaders from Kubota most likely WERE available; however, they don't make the tractor any more, and probably don't make the loader any more either (parts are available). You might be able to find a used one somewhere if you are lucky.
Woods still makes loaders for some of the older B-series hydrostatic Kubotas (for example, as of Summer '98, they still offered loaders for the B7100HSD, but not for the B7100D [gear drive]).
/ B5100 Loader? #3
I believe that tractor used the B1630A loader which was used on several other tractors. Check out the manuals section of the is website for more info.
/ B5100 Loader? #4
hi i have a B-4200 - its the same basic tracter as the B-5100 - i have a loader from the factury on its - a 1620 MODEL - if you want i,ll glady send you more info or a picture as i got the book on it as well good luck - Gord
/ B5100 Loader? #5
I have a B5100 as well. I went with a rear dump bucket from JohnnyBucket. It works great for moving materials around, as long as you don't need to go above 24". It was also only $500. I've got pics if you'd like to see. It is a compromise - but it leaves about $1000 left over for other toys : )
/ B5100 Loader? #6
“Check out the manuals section of the is website for more info.”
What manuals section on what website? I would like to look through a manual for my B5100. By the way I have a PDF file that has a parts manual for a B5100.
Thanx for your help
Roger
RAIN FLOW HOLE PUNCH, 3PT (A63291)
RAIN FLOW HOLE...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63276)
KNOW BEFORE YOU...
iDrive TDS-2010H...
KOMATSU PC88MR-11 EXCAVATOR (A64279)
KOMATSU PC88MR-11...
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
Knapheide Service Body w/ Ladder Rack (A62613)
Knapheide Service...
