B5100 Loader?
/ B5100 Loader? #1
whome
I realize a B5100 is kind of small but can these tractors be equipped with a front end loader? Thanks for any input.
/ B5100 Loader? #2
B5100 loaders from Kubota most likely WERE available; however, they don't make the tractor any more, and probably don't make the loader any more either (parts are available). You might be able to find a used one somewhere if you are lucky.
Woods still makes loaders for some of the older B-series hydrostatic Kubotas (for example, as of Summer '98, they still offered loaders for the B7100HSD, but not for the B7100D [gear drive]).
/ B5100 Loader? #3
I believe that tractor used the B1630A loader which was used on several other tractors. Check out the manuals section of the is website for more info.
/ B5100 Loader? #4
hi i have a B-4200 - its the same basic tracter as the B-5100 - i have a loader from the factury on its - a 1620 MODEL - if you want i,ll glady send you more info or a picture as i got the book on it as well good luck - Gord
/ B5100 Loader? #5
I have a B5100 as well. I went with a rear dump bucket from JohnnyBucket. It works great for moving materials around, as long as you don't need to go above 24". It was also only $500. I've got pics if you'd like to see. It is a compromise - but it leaves about $1000 left over for other toys : )
/ B5100 Loader? #6
“Check out the manuals section of the is website for more info.”
What manuals section on what website? I would like to look through a manual for my B5100. By the way I have a PDF file that has a parts manual for a B5100.
Thanx for your help
Roger
3pt 6 Row Cultivator (A64119)
3pt 6 Row...
2019 Jayco Octane T32H Toy Hauler (A62613)
2019 Jayco Octane...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
Rhino Servis 2160 Ditch Bank Mower (A62180)
Rhino Servis 2160...
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
