b5100 charging problem
/ b5100 charging problem #1
mig welder
Cork,Ireland
kubota b5100
Hi all just bought a b5100 one owner tractor which has got very little use but it is not charging the battery.Everything on the tractor is origional and everything else works.Has anyone out there got a wiring digram or maual they would email me to get this little gem sorted?
/ b5100 charging problem #2
Haven't got any diagrams.
Check the AC/DC rectifier behind the dash panel (the finned thing).
To do this check whether the two wires from the dynamo will light a test light (battery disconnected, engine running). I think you'll find two bullet connectors somewhere below the exhaust manifold, make sure they're contacting.
If there's power up to the rectifier check the remaining wires on the rectifier (3 I think) to see whether any combination will light the test light (as above).
If there's power into the rectifier, but not out, it must be a faulty rectifier.
Good luck
/ b5100 charging problem #3
Here's a scan of my B7100 electrical diagram. It may be the same as your 5100.
/chris
:D just got time to look at the b5100 again today and after following wires found a wire off the iginition switch.After connecting it everything seems to work and it is charging at 14,5 volts at 50% revs.thanks to those who replied and the wiring is the same as the b7100.
2010 KEYSTONE LAREDO (A65643)
2010 KEYSTONE...
Quick Attach Rock and Tree Hand (A65579)
Quick Attach Rock...
Heaven Hill Burbon Barrel (A65583)
Heaven Hill Burbon...
2022 EZ-GO ELITE...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
Cattle Feeder (A65640)
