Kubota B3200, LA504 FEL, BH76 Backhoe & Toro Z-Master 3000
Hello all, I have a B3200 with a BH76 and factory installed rear remotes that the previous owner ran a stump grinder off of. What is involved in using a 3rd function kit, like WR Long, and plumbing into my current system? I'd like to be able to use a grapple with my backhoe is mounted/connected to the hydraulics if possible. I have little hydraulic experience, so I'm needing some guidance. Thanks.
1.9 MB
1.6 MB
1.8 MB
/ B3200/BH76, rear remotes and adding 3rd function kit?
The manual for my L3430 and BH92 hoe says not to use the rear remotes with the BH attached. Hydraulic system damage could result. I don't know if this is the case with the B3300 though. If member dmiele above is using his rear remotes to operate his grapple, it may not be a problem. I would check your manual though.
FWIW, I installed a W&R Long 3rd function valve on the L3430 a few years back. The kit cost $795 and it took about an hour to install. The instructions were clear and no special tools were necessary.
