B3030HSDC with Backhoe
/ B3030HSDC with Backhoe #1
littlediesel
Baldwinsville, New York
L45 TLB, U35, KX71, U17 Excavators, B3030HSDC, F3680, ASV PT40
Has anyone put a backhoe on their B3030HSDC (factory cab model)? I am thinking about buying a backhoe for my B3030 and would like to know some experiences of anyone who has one. Also, would anyone have any pictures they could post with the cab model tractor and backhoe! I would appreciate any feedback!
Thanks,
Jon.
/ B3030HSDC with Backhoe #2
The dealer told me they could mount up a backhoe on my B3030 HSDC with some tweeking, sounded a little scary to me?
/ B3030HSDC with Backhoe #3
One of the local Kubota dealers put a woods backhoe on a B3030HSDC, and it looked like it would work well. I believe the hoe was a BH80x. The Woods mount puts the backhoe just far enough to the rear that everything seems to clear the cab fine.......
Good luck!
Chuck
/ B3030HSDC with Backhoe #5
Hi,
I am just about to pull the trigger on a new B3030 with FEL, Woods Bh80-X and Snowblower. I was not getting the Cab version but am now having second thoughts. Do you know the price difference between the B3030 with and without the cab??
Thanks
/ B3030HSDC with Backhoe #7
Is the backhoe compatable with the cab?
/ B3030HSDC with Backhoe #8
The factory Kubota backhoe is NOT supported when you purchase the cab model.
Woods does support their backhoe models on the cab. Just search the threads here on Tractorbynet and you will find mention of the B3030HSDC with Woods 80x and 70x bachoes.
FYI,
Norm
/ B3030HSDC with Backhoe #9
I'm sure you're correct, I just knew I had read somewhere that the cab model/backhoe was an issue. Wasn't trying to tell you you couldn't, was just trying to point out the issue and stop a possible mistake/problem. Good luck with it.
/ B3030HSDC with Backhoe #10
I'm about to have a BH80X mounted on my b3030hsdc. The dealer says no problem. That's a 4 pt hitch, hyd. from the tractor. With factory installed thumb. It weighs about 900 lbs installed with frame. The correct frame extends out about 6 inches beyound the normal mounting of a non-cab model.
Pricing from my dealer is $7300 installed with thumb or $6500 for BH70X. It looks and specs are pretty aggressive. About 4000 lbs of bucket force. I'll post a pic when it's installed.
Thanks for the info. I will look forward to seeing the pictures.
Jon.
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63688)
2004 Cadillac...
Unverferth Field Cultivator (A64127)
Unverferth Field...
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
