Snow B3030HSDC joystick freezing up in bitter cold
/ B3030HSDC joystick freezing up in bitter cold #1
Michford
Michigan
Kubota B2650HSDC, 1955 Ford 860 with Sherman Napco 4WD, 1958 Ford 841 with Elenco 4WD, 1959 Ford 641
I'm having an issue with the cable to raise and lower my front snowblower freezing up and not allowing the joystick raise and lower to function. When I used it last weekend, it was a little stiff but loosened up as I used it. I always clean off the tractor and blower and sweep off the snow after using it, and it got stiff while I swept it off. Tonight out of curiosity, I went out to my pole barn to see if it would be stuck, and sure enough it was. I aimed my salamander heater at the low point in the cables under the cab and a few minutes later, the joystick was freed up. Looks like I'll be disconnecting the cable at the valve and seeing if I can get the ice/water out of the cable housing. Anybody else ever run into this? I replaced both cables three years ago.
/ B3030HSDC joystick freezing up in bitter cold #2
Wow,three years already!
Sounds like you're on the right track.
Could pour in air brake antifreeze to free it up until better weather to drain and relube.
But where did the moisture come from?
Good Luck!
Northern lower Michigan, we might almost be neighbors. I'm south of Traverse City. I may try Fluid Film as a lubricant on the cables. I used it on the snowblower chute rotator gear and it has prevented it from freezing up so far this winter.
Thanks Lou, great tip on the specialized tool.
/ B3030HSDC joystick freezing up in bitter cold #7
I think you will find the Kubota cables are a more complicated design than the typical motorcycle cable tool is intended for.
I bought a large animal syringe at a TSC store and used its needle to pierce the rubber seal and inject gas line anti freeze into the cable.
Dave M7040
/ B3030HSDC joystick freezing up in bitter cold #8
I have never tried but I had an old timer tell me that he used to use pieces of hose to fit snug over the outer cable sheath on both ends and then use a vacuum brake bleeder to draw lube into control cables. Sounds like a lot of work to me by the time you get both ends of the cable disconnected. I just keep spraying lube on the higher end of the cable an exercising it.
I have used the motorcycle lube tool on choke, fuel shutoff and throttle cables if works fairly well for them.
/ B3030HSDC joystick freezing up in bitter cold #9
Sure it’s the cable? Look at the loader valve that cable runs to. On opposite side where cable enters their may be a couple spring caps. These often have water in them that freezes. Often as warmer oil circulates in valve, it warms up and becomes easier to use. Unscrew cap and drain.
Quick test would be to heat caps only next time it freezes, with a hairdryer or quick flick with propane torch and see if lever releases frees up (not freeze up).
/ B3030HSDC joystick freezing up in bitter cold #10
Not quite neighbors.
Tip of the Mitt
30 minutes south of the bridge.
Looking foward to your findings.
My somewhat garage-queen has never done that,even in cold storage for extended periods.
Good Luck!
Here are pictures of what I found at the cable end at the external valve 3 years ago when I took it apart to replace cables. Was rusted from moisture and stuck.20181215_093858.jpg
And here are pictures of the new cable from 3 years ago. There does not seem to be any rubber seals at the ends.20190110_204238.jpg20190110_204238.jpg
Cable seemed to be frozen at the low point under the cab as it freed right up with the salamander heater aimed at it. I will be pulling it back apart at the valve end to lube and will try a little heat on the caps on the valve out of curiousity to see if it pops free before digging into cable.
Here are pictures of what I found at the cable end at the external valve 3 years ago when I took it apart to replace cables. Was rusted from moisture and stuck.View attachment 686270
And here are pictures of the new cable from 3 years ago. There does not seem to be any rubber seals at the ends.View attachment 68627120190110_204310.jpg
/ B3030HSDC joystick freezing up in bitter cold #13
How did your problem get resolved?
I'm sure I will be in the same place down the road.
Thanks for posting.
/ B3030HSDC joystick freezing up in bitter cold #14
I used a heat gun when my joy stick froze up.
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
1992 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1992 AM General...
2021 CATERPILLAR 299D3XE SKID STEER (A60429)
2021 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
KUBOTA L2501 TRACTOR (A60430)
KUBOTA L2501...
UNUSED FUTURE FT-GB200-79"X71 1/2"-1" STEEL PLATE (A60432)
UNUSED FUTURE...
