B3030 turns over, but will not start. Help? :)
   / B3030 turns over, but will not start. Help? :) #31
I'd thought I'd chime in with my experience on a 2005 B303, which has been similar.
Ours died after nearly full throttle with a decent load and wouldn't restart. (We're also at 8000ft). I thought I'd take a look at the fuel filter, which was quite bad. I replaced it but it still wouldn't start. I decided to loosen the fuel pump both and turn it a very times to get the fluid flowing there. Wouldn't start. Then I loosened an injector, turned it over a few seconds, got some fluid flowing from the injector and it started after about 30 seconds. It ran a little rough for a minute or so then settled out. I ran it a few minutes and it seemed to be back to normal. The true test will be starting it again in the morning to be sure it's back to normal.
Anyway, my experience was likely a very bad fuel filter then needed to bleed the system.
2018 Allmand Light tower (A49461)
2018 Allmand Light...
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2011 Kubota M7040SUD 68HP Utility Loader Tractor (A49461)
2011 Kubota...
WASTE OIL TANK (A50854)
WASTE OIL TANK...
SOLDERING IRONS, GLOVES, AND STANDS (A50854)
SOLDERING IRONS...
