b3030 tlb hydraulic add ons?
   / b3030 tlb hydraulic add ons? #1
workinallthetime
Tulsa, ok
L45 TLB, ZD326P
i am thinking of adding a grapel, hydo top link, and a hydo thumb
just what am i l ooking at getting involved with here?
what do i need?
prices and web sites would be apreciated,
thanks
   / b3030 tlb hydraulic add ons? #2
The cleanest way to add rear hydraulics to the B3030 is with the Kubota Rear remote options - about $500 per IIRC thru "wholegoods" - you can get up to 2. Stock numbers & MSRP here B series 2007
You can also use "COTS" valves - plenty of threads here on how to do that by tapping into the FEL power beyond port. May be less $$ but significantly more head scratching involved.
The cleanest way to add grapple capability is with a 3rd function or solenoid selector valve from WR Long - ~$400 IIRC.
The alternative would be to plumb hydraulic hoses from the rear remotes to the front for the grapple.
The easy way to power the thumb would be from one of the rear remotes. The fancy way would be to add a foot switch ala the Woods BH90-X option - see here for details - woods hydraulic thumb manual You'd have to engineer the cylinder size, mount & thumb etc for your hoe.
an easy toplink solution is available here CCM (tbn sponser). I have the 18 - 26.5" version on my B3030
thanks haz your da man
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2012 FORD F-650 SUPER DUTY BOX TRUCK (A51243)
2012 FORD F-650...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2000 GMC C7500 ANCHOR DRILLING TRUCK (A50854)
2000 GMC C7500...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
