B3030 side glass windows in a B3000 ?
   / B3030 side glass windows in a B3000 ?
Hi moship.
I'll send a pm with my email.
Thank You!
I have learned that there is a fundamental difference in the Cab structure between the B3030 and the 3000. It's even a different part number for the cabs.
The B3030 that uses the opening windows has little nubs/tabs welded as part of the cab to allow the attachment of the hinges etc for the articulating windows.
The B3000 cab has none. It would require some metal work and welding.
Not sure it's worth it......
   / B3030 side glass windows in a B3000 ? #12
Pictures sent.
There are some attachment details that are part of the cab frame the hinges and closing attachments attach to. It wouldn't require too much fab, but the effort/cost may not be worth it.
Does the back glass tilt outward on your cab? The B3030 back window is hinged at top and opens at the bottom.
Let me know if you didn't get all four sets of pictures.
Pictures sent.
*****The flanges are not there on the B3000. IT's even a different Cab part number with Kubota. Ya... I guess I could get someone to Fab them for me, but as you said.... it t worth it?
***** Yes, the rear glass on the B3000 opens the same as the 3030.*****
***** I did get all four sets.... THANK YOU. *****
See my responses inserted above.
Thanks a lot for your help and the Pics.
2020 MACK P164T (A58214)
2020 MACK P164T...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56435)
PENDING SELLER...
Bobcat T590 (A53317)
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2011 Ford Crown Victoria Sedan (A54815)
2011 Ford Crown...
