B3030 Shims?
   / B3030 Shims? #1
JJZ 109
Veteran Member
Lake Ontario/St. Lawrence River
Kubota BX2380/LA344 loader/60" MMM, Bobcat S185 skid steer, JD X394 4 wheel steer mower
In the midst of adding a Washburn SSQA to an LA 403 loader on a B3030. Will also be buying a set of QA pallet forks.
Would shimming the hydraulics to slightly increase the pressure help to offset some of the capacity lost by the SSQA with bucket or forks being out front of the lift arms more than the stock pin on (non QA) setup? Not looking to spring a lift arm or otherwise damage loader or tractor.
   / B3030 Shims? #2
You should get simple gauge setup, and see what your PRV (pressure relief valve) is currently set at now...Kubota has a history of them being low from the factory.
You can make one for about $35.00 or less, see my picture below. I have since replaced the 12" hose with a 36" hose to make it easier to use.
   / B3030 Shims? #3
Of course you can always increase the pressure... But that's not really a great idea. Check the pressure you now have, It can be low for a few reasons, weak spring in relief valve, or oil viscosity shearing down, or initial setting low... See what you have and if it is at spec... try doing what you need done with it... If it is just marginal, you most likely will just get buy. If it is less than 'just marginal', you may be needing to consider a larger machine...
KennyV
   / B3030 Shims?
Just happened to be searching the site and stumbled upon a post from Feb. 2009 when I was shimming the JD 790 that I had at the time. Many posts there from both of us!
I did in fact make a gauge back then and it still sits in my tool box. Next step is to check the stock setting next time I have the tractor out of the barn.
If in fact it could use a boost, will this address the issue that I mention in the original post? I don't really want to max it out, but what does anyone recommend for reasonable PSI? If shimming does come into play, can someone chime in here with a Kubota part # for me? Much appreciated!
BTW, this is a low (65) hour tractor. I would hope that there are no worn springs, etc. in the valve. But of course there are never any guarantees.
   / B3030 Shims? #5
Well good...so see what you have now and compare it to the specs.
   / B3030 Shims? #6
Please post some pics of the process if you do have to adjust your pressure. I need to get off my dupa and buy a guage and check mine also.
   / B3030 Shims?
If I got off the dupa I'd already have used my gauge. :laughing: Hard to get much done when it gets dark so soon after work. The pellet stove, recliner and faithful golden retriever at the feet don't make it any easier. ;) Maybe when the QA stuff arrives from Washburn I'll kick things into gear a little quicker.
Looking at my shop manual, the relief valve appears to be just ahead of the right side (looking at tractor from rear) lift arm. It states that the relief valve setting pressure on a B3030 should be 2204 to 2306 psi at rated engine speed and oil temp at 122° F.
The setting is 1920 to 1991 psi on a 2620 if anyone with that model is following along.
   / B3030 Shims?
Wouldn't you know it? Went out to check tonight and the quick connects aren't the same size as on my former tractor (JD790).
Local NAPA ordered the correct fitting to crimp onto the gauge hose and an extra female QC like is on the loader hydraulic lines to screw onto it. Will post when I get the pressure checked.
   / B3030 Shims? #9
I thought that might be the case, JD uses Pioneer QD's, while Kubota does not. Shoulda stayed green:laughing::laughing::laughing::laughing:
   / B3030 Shims?
I wanted to stay green. But it seems to me that at the time (Feb. 2009) JD's smallest tractor with factory cab (3320?) was much more $$ than orange's 30 hp class tractor with factory cab. Oh well. The l'il fella does everything I've needed so far.
   / B3030 Shims?
OK, here's what I have:
Shop manual shows the relief valve on right side of tractor just ahead of the lift arm. The section mentions implement control so I believe this is what I want to check. Recommended pressure is 2204 to 2306 psi.
In another part of the manual it mentions relief valve for 3 points (their wording) hitch. Relief valve pressure there is shown as 2175 to 2320 psi.
Which one am I looking to check for the loader? At any rate, my gauge showed an even 2500 psi where the loader lines connect. This has not been tampered with by me. It came from the dealer as is. Sounds like the whole shim thing is moot for me now.
   / B3030 Shims? #12
At any rate, my gauge showed about 2500 psi exactly where the loader lines connect. This has not been tampered with by me. It came from the dealer as is. Sounds like the whole shim thing is moot for me now.
Yup, just wait till you get the new QA and see if you notice a huge difference.
   / B3030 Shims?
There's bound to be some difference, but like I said elsewhere the machine doesn't really get any heavy duty use. Some snow removal, occasional dirt and driveway stone work and picking up 350 lb. rolls of aluminum seamless gutter coil.
Seems a shame to have to cut the factory brackets off the bucket for the QA plate, but it is what it is.
   / B3030 Shims? #14
It only made mine better............ but I suppose I did have closer to 300 hrs. on mine at the time.
2024 JCB 35Z (A60462)
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
2017 Ford Transit 250 Cargo Van (A59230)
2017 Ford Transit...
2008 GENIE S-65 TELESCOPIC BOOM LIFT (A60429)
2008 GENIE S-65...
Chemical Containers Tank (A57148)
Chemical...
2015 VERMEER PD10 PILE DRIVER (A60429)
2015 VERMEER PD10...
