B3030 seat problem
/ B3030 seat problem #1
fishhead
I can't seem to keep the edging material (I think it may be called trim-lok) in place around the edge of my seat. Once enough of it comes off it becomes a bear to get back on over the seat covering around the corners. I am thinking of contact cementing the actual seat material to the metal seat edge so that replacing the trim becomes easy. Any thoughts as to why this might be a bad idea? Are others having this same issue?
Many thanks
/ B3030 seat problem #2
How long have you had the tractor? Have you talked with your dealer?
I bought mine last June. No problems with the seat to date. Not even any signs of wear or movement of the binding material.
What about something like silicone to hold the binding in place?
D
UNUSED WOLVERINE TREE DIGGER (A64281)
UNUSED WOLVERINE...
EZ Trail 3400 (A63688)
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
2021 JOHN DEERE 844L WHEEL LOADER (A65053)
2021 JOHN DEERE...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
