B3030 seat, it stinks!
   / B3030 seat, it stinks! #11
I think the seat on my new B7610 seems to lean forward way too much! I always feel like I about to slide off. I need to look into adjustments of some sort.
   / B3030 seat, it stinks! #12
I'm getting the f3680 seat put on my b3030 that neil messick recd - I'll post a report once I've used it for a while. The seat was my least favorite part of the machine testing it out.
   / B3030 seat, it stinks! #13
Yes it's not the most comfortable seat if you spend a few hours in it - especially for something called "Delux". I loosened the suspension for a softer ride. For the forward lean, I installed 4-5 washers under the front bracket and reinstalled the nuts and that has helped considerably. A few washers are cheap and worth a try for the forward lean.
I have gone back & forth on this 3030 seat, sometimes it's not too bad, but after long hours, 6 +, it really gets uncomfortable. I was in the curtis cab of my B7500 for 30 straight hours plowing sidewalks in a condo complex during a january blizzard back in 2002, i thought my butt would never recover! That B7500 seat was rough.
   / B3030 seat, it stinks! #15
Lawn King, i suggest a few more burgers and fries. Pack on a little extra padding on the backside, and you'll be fine !
I dont need any extra lbs thanks. Since lesco came out with their HPS, articulating ride on spreaders powered by mr. kawasaki, i now carry an extra 20 lbs. The 3030 seat sucks, no nice way to put it!
   / B3030 seat, it stinks! #17
I installed the F3680 seat on my B3030 and have spent about 6 hours of "seat time" since the install...however, in 2 hour installments on three separate occasions. I must say the difference is beyond description...at least for me!! While I have not had any lengthy time in the seat, it's cushioned ride cannot even be compared with the original seat. It really does take a lot of the roughness out of the ride...not to mention the sensation that you're about to slide down under the steering wheel.
However, I will CAUTION you!!! I found the idea that the install is a "drop-in" replacement didn't compute with me. Either I'm engineer challenged or the mounting mechanism used by Messik's customer was considerable different. I purchased the seat through "wholegoods" and retrofitted the mount for the mounting brackets on the original seat. I lost the slide feature of the original seat, but that was not a concern since I'm the only one to use the tractor (won't let my wife near it!). The F3680 seat has a seat safety switch on it and I simply converted the live rear PTO safety switch to a push/pull switch located under the seat...still requires a conscious decision to engage the rear PTO while not in the seat...and is located in a position that makes accidental activation very unlikely. Installation wasn't easy, but wouldn't trade for twice what I paid for the seat!!!!!!!!!
   / B3030 seat, it stinks! #18
I really thought I wanted a Kubota until I drove several of them. I couldn't get comfortable in any of the seats. They always seem to lean forward too much. I finally bought a Case DX. I think the Case New Holland seats are far superior. There have been many comments about the comfort of Kubota seats in this forum. I think they need to listen and improve the seats. I would be a Kubota owner if the seats were better
The kubota seat issues go on & on. I dont have a problem with the foward lean, my lower back gets very uncomfortable, almost numb, after extended hours. I really dont think washers under the mounting bracket will work for me. I think kubota should stop calling this a delux seat. Im just going to have to bite the bullet and shell out the coin for a nice seat, lazy boy perhaps?
   / B3030 seat, it stinks! #20
Sounds like a vacuum seat, you need an air seat.:)
2025 Unused JBX 4000 Skid Steel Fork Attachment (A49346)
2025 Unused JBX...
2003 Volvo S60 Sedan (A50860)
2003 Volvo S60...
2024 Dodge Durango SXT AWD SUV (A48082)
2024 Dodge Durango...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A51039)
Mitsubishi FG35...
2001 GMC Jimmy SLS SUV (A48082)
2001 GMC Jimmy SLS...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A49346)
2025 Kivel 48in...
