B3030 plugs
   / B3030 plugs #1
Lanse
Bronze Member
I just got my B3030 and was wondering if there are any glow plugs in there. When you turn it to the position, all that happens is the light on the dash lights up. On my holland there is a loud clicking noise. Are there any plugs in there or do I have to buy them too???:confused:
   / B3030 plugs #2
Your B3030 has glow plugs. When you hold the key and the light is on you are working the glow plugs. No loud clicking just a light.
   / B3030 plugs #3
When you turn the key, the light for the glow plug is yellow/gold. It's located directly under your red battery indicator light, and directly to the left of your fuel gauge. Looks like a yellow horizontal spring. Let us know if you find it, if not I'll send a picture over to you.
Frank
   / B3030 plugs #4
When I turn the key on my B3030 there is a very loud single click. I believe this is the fuel solenoid. The oil and battery light are on. Turn the key a little to the right and the glow plug indicator should light up. Turn the key a little more to engage the starter.
This procedure is in the owner's manual.
Vic
   / B3030 plugs #5
It's also worth mentioning that unlike some diesel vehicles, there isn't a timed glow plug relay that breaks the circuit automagically. The glow plugs will stay lit indefinitely as long as you hold the key in that spring position. Usually just a few seconds is adequate, slightly longer in colder weather.
I haven't yet bothered to track down what makes that loud 'click' when you turn the key on... that would have to be one beast of a fuel solenoid to be that loud! It sounds more like a big contactor pulling in.
   / B3030 plugs #6
That was probably a bad guess on my part. It does sound like Victor von Frankenstein is getting ready to go to work.
   / B3030 plugs #7
Hehehe... good analogy
   / B3030 plugs #8
Lanse - Where are you located? Just curious because there is a town a few hours from me named Lanse. You wouldn't happen to be in the U.P. would ya? Thought there might be another yooper on the forum.:)
   / B3030 plugs
Gee, thanks!! You guys are the best!!! I LOVE THAT TRACTOR!!! YEEEEE-HAW
   / B3030 plugs #10
What am I missing here?
Just got my (Used, no manual) B3030 and have yet to see the glow plug indicator stay on.
Seems the ignition switch has only 3 positions, off, on, start. No turn CCW position, just off, on, start. The light comes on briefly in the start position.
Is there a temperature sensor in the circuit?
Haven't tried to start it below 70 deg yet, that's about as cool as it's been here.
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A49461)
2011 Kenworth T300...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2015 International DuraStar 4300 Street Sweeper Truck (A50323)
2015 International...
2016 Ram 1500 4x4 Crew Cab Pickup Truck (A49461)
2016 Ram 1500 4x4...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
