B3030 observations
/ B3030 observations #1
ronjhall
Super Star Member
SW Oakland County Michigan
2, Kubota B2910 HST
During a visit to a dealer I was able do some comparisons between a B7800, B2910 and B3030. These are just My opinions after about a 30 minute visit.
My visit was to determine if a 403 loader will fit my 402 FEL attachments. They will not. Loader arms are closer by 3 3/8".
*A B7800 was setting next to the B3030. Both tractors had the same AG tires.
*B3030 hood sets above B7800 about 6". It appears tractor is setting higher above the front and rear axles.
*This is probably how 6" additional lift was gotten on the new 403 loader.
*Deck-foot rest appears to be higher also.
*Toolbox is behind seat.
*Cup holder is also behind seat left side. It would be difficult for me to reach back to get a drink.
*There is a plastic cover on right fender where 2 additional valves for T&T will be placed.
*Played with a metal pedal on right side of foot platform. This pedal controls the steering wheel tilt.
*Cruise control is now in the fender. Should be better than 2910's cruise control and will not be engaged when getting on and off tractor.
*There is only one neutral for 3 drive ranges. Lever must be put in Neutral to start. B2910 only required clutch be pushed in to start.
*There is no clutch on B3030. PTO is now hydraulic. I'm not sure this is a good thing or not.
*Front grill has been modified. It now has to bolts holding it on. B2910 had push on clips.
*Radiator screen is the same. Air cleaner has been modified to allow easier removal of screen. But still requires that snorkel be raised to get screen out.
I did not drive B3030. But like it's overall appearance. Just not sure that being about 6" higher is a good thing or not.
I hope the next time I inspect one, I will get to drive it. /forums/images/graemlins/grin.gif
/ B3030 observations #2
Thanks for your observations. /forums/images/graemlins/smile.gif
I just want to say that the metal pedal to adjust the steering wheel tilt is on left side.
Last time I went to my dealer I took some pics of my B3030 but it wasn't ready yet. The BH75 wasn't mounted neither the belly mower. It should be home next week... around monday.
I saw too the plastic cover on the right fender. I think this is cool to have the possibility to install factory auxiliary valves integrated into the right fender. The problem is the price of these valves.
I don't understand why they've put the cup holder behind the seat. /forums/images/graemlins/confused.gif I'll have to install an other one.
I'll post some pics I took that confirmed your observations. As you can see on this pic, I couldn't have compared it with other B series because on the left is a... L3430 (or so) and to the right a... L3400 (I think).
Is your B3030 ordered?
Thanks again... /forums/images/graemlins/smile.gif
/ B3030 observations #3
This one is about the trap for the valves and the cruise control.
/ B3030 observations #4
This one is... the left fender.
/ B3030 observations #5
I like the new dash. Ouhh... 24 minutes on the clock counter.
/ B3030 observations #6
On this one: the metal pedal (bottom left).
Ron I have a question. How many levers below the dash have you seen on the B3030 you looked at? Because on my pic there's only one for the parking brakes. But when I look at the B3030 brochure, the pic of the B3030 interior (cab model) has two lever like a B2910. /forums/images/graemlins/confused.gif I asked my dealer but he doesn't know the answer.
/ B3030 observations #7
As I said, my B3030 wasn't ready when I took the pictures so that's why my mower was in a crate.
/ B3030 observations #8
The same for the BH75. /forums/images/graemlins/confused.gif
/ B3030 observations #9
I don't know why I took a pic of the hitch but there it is.
/ B3030 observations #10
<font color="blue">*There is no clutch on B3030. PTO is now hydraulic. I'm not sure this is a good thing or not </font>
My conclusion is that it is not a good thing when using a post hole digger...
I only say this because it was just recently that I realized how much I would not like using a PHD on my BX2200. The reason being that the PTO is activated with the left hand and the 3PH is operated with the right hand...no way I could be looking back at the PHD and raising/lowering it, while at the same time maybe stopping and starting it, to throw dirt off the auger and save manual hole clean out work.
Other than the PHD, it may be a non issue...
Personally, the lack of a foot-operated clutch is a negative in my book. I don't think this is resistance to change on my part, but really just a practical consideration.
Actually, now that I think about it, the hydraulic clutch on my BX2200 is one of the things I really don't like. If I did not have the B2910 I might not know better. There is no control on the hydraulic PTO...bang and it's engaged. Very difficult to feather...I live with it as there is no choice, but much prefer the foot-operated clutch on the B2910.
<font color="blue"> Is your B3030 ordered? </font>
I have been waiting to find what the dimensions of the 403 loader was going to be compared to the B2910. With all the differences, including the clutch I do not think I will be ordering one. /forums/images/graemlins/frown.gif
Maybe taking the cash I had set aside for the B3030 and use it to buy a power rake. /forums/images/graemlins/grin.gif
Henro
I'm with you on this one. I believe that this is a cost savings to <font color="orange"> Kubota </font>.
That may not be a great option in all cases for the operator/owner.
/ B3030 observations #13
I agree Henro,
more often than not it is desireable to have a clutch to feather the implement startup. It will avoid trying to instantly bring a large mass up to speed. Wouldn't it be near impossible to run a pto chipper without a clutch to start it? But there must be some feather capability with the pto, just for the previously stated reasons. Did I miss something in the prior posts?
Now, looking at Stef's pics and in particular the hitch area... when I was out tractor shopping to replace (supplement) my wheel horse, my greatest concern and the one that put me off smaller machines was the over hang of the rear axle from the case. Taking a good look shows the over hang to be greater in length than the distance between the support bearings. Has this ever been a concern of yours, has it ever caused anyone any problems at all?
Thanks,
Martin
The spacing you see in the pictures is the same as the current B27-2910 and B7800. There has no problems reported on TBN of axle bearing failure. I have 1 1/2" spacers on my wheels with no problems. If you are using the spacing to determine which CUT you will buy. You may be limiting many tractors that are very capable from a list of tractors to purchase.
/ B3030 observations #15
<font color="blue">But there must be some feather capability with the pto, just for the previously stated reasons. Did I miss something in the prior posts? </font>
AntrimMan,
With my BX once in a while I get lucky and it almost feels like I can feather the hydraulic clutch as I try to slowly engage it.
But most of the time is pretty much just engages real quick. Part of my problem could be that there two "detents" in the plastic slot the lever rides in, and one needs to pull the lever left, then push it right, as it is moved to the engage position, and this may hinder one's ability to feather engagement somewhat. I have heard at least one person has trimmed these little "tabs" off, I assume to make lever movement easier...
All I can say is that I used to try to feather the hudraulic clutch when engaging it at low RPM with the MMM on. I don't bother anymore as the result (or lack of one) most of the time was not worth the effort...
It is possible that the hydraulic clutch has some feather built into it, just not as much feather as I would normally employ when using a foot clutch. All I know is that for me, the MMM starts almost shockingly quick, when compared to what it would do if I were controlling it with my foot on a clutch pedal...
/ B3030 observations #16
I agree, Henro. I've used a post hole digger on a tractor with the hydraulic PTO clutch instead of the foot clutch, and I guess it's not a big deal, but I liked using the foot clutch on my Kubotas better.
/ B3030 observations #17
Its my understanding that the tractor does automaticly have some level of feathering built into the hydraulic engauging system. All the L-Series tractors are like this, makes sense to put the technology into the B's as well. I do agree that for a PHD a clutch is defentialy handy. The vast majority of customers will be glad to see it gone, but I can see why you would you want it.
2012 23ft Chaparral Sunesta Boat with 22ft. T/A Continental Boat Trailer (A61574)
2012 23ft...
2022 EZ-GO ELITE...
NEW HOLLAND TC35A TRACTOR (A64280)
NEW HOLLAND TC35A...
2019 CATERPILLAR TL642D TELESCPOPIC FORKLIFT (A62129)
2019 CATERPILLAR...
2019 Ford F-150XL (A64119)
2019 Ford F-150XL...
APPROX (80) PIECES OF 48" X 56" EXPANDED METAL (A64280)
APPROX (80) PIECES...
