For heavy pulling, I use the ball on the tow ball. For light duty stuff, like the log splitter, I use the hitch. (Pic shows it; I had the bracket fabbed, the draw bar is from TSC.) Tractor is used for snow removal, so nice in winter time. Green house effect can be a problem with temps over 60 degrees--need to run ac. Cab can be a nuisance in trees or if you have a clothesline to go under.
AStanton, how is the bracket attached to the draw bar? Can't tell from the photo. Thank you, Stanley
Those are threaded: A 1- 1/4" nut holds each end.
