B3030 Moving Trailer
/ B3030 Moving Trailer #1
AStanton
North Central, CT
Still playing with firewood around here. Used the B3030 to move its trailer away from the firewood to get more room. Moving the trailer it's suppose to ride on is like: "Man bites dog."
/ B3030 Moving Trailer #2
It looks like your machine is brand new! How do you like the cab? Do you have a ball on the tow bar or on a 3 point hitch device?
For heavy pulling, I use the ball on the tow ball. For light duty stuff, like the log splitter, I use the hitch. (Pic shows it; I had the bracket fabbed, the draw bar is from TSC.) Tractor is used for snow removal, so nice in winter time. Green house effect can be a problem with temps over 60 degrees--need to run ac. Cab can be a nuisance in trees or if you have a clothesline to go under.
/ B3030 Moving Trailer #4
AStanton, how is the bracket attached to the draw bar? Can't tell from the photo. Thank you, Stanley
2013 FREIGHTLINER M2 112 S/A 4X2 DAY CAB TRUCK TRACTOR (A59910)
2013 FREIGHTLINER...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
2025 DORSEY 48' STEEL FLATBED (A59910)
2025 DORSEY 48'...
Rhino SE8 Rotary Cutter (A64047)
Rhino SE8 Rotary...
