B3030 Kubota won't start fixed
   / B3030 Kubota won't start fixed #1
Popb1949
Drummonds,Tenn.
2 Kubota B 3030HST, B2710, B2320, RTV900
My B3030 Kubotas starter would not turn over after shutting it off and trying to restart it.
Checked the HST neutral start switch And found that it had fallen from the bracket and was hanging by the wires.
Looks like a common problem for all B series Kubotas for this switch to get loose!
Same problem once on a B2710HST.
Any one else ever had this problem on a B series Kubota.
   / B3030 Kubota won't start fixed #2
I can't answer for specific Kubotas, but you'll find that vibration will loosen anything on any piece of equipment.
You just have to keep an eye on things. Keeping your wheel nuts at the correct torque is important and, if you want, adding lock-tight to bolts/screws will hopefully arrest future problems.
   / B3030 Kubota won't start fixed #3
Do the simple things ,giggle footpedal back and forth , move pto lever while trying to start, another option is to jumper wire the safty switch on foot pedal and PTO then try to start . Non starting ? OPC modual comes in to play !!!!!!!!!!! CHECK THE VOLTAGE REGULATOR WIRE GOING TO OPC MODUAL , THIS SHOULD PRODUCE 12VOLTS TO YOUR OPC MOdUAL WITH THE KEY ON { white wire red tracer } This activats start power to solenoid inside the modual . Beleive me I have lost some hair and $$$ over this one !!!!
FAKE (A52472)
FAKE (A52472)
2017 Snapper Pro 48in Zero Turn Commercial Mower (A51691)
2017 Snapper Pro...
2013 VERMEER VACTRON LP555 DT HYDROVAC TRAILER (A52472)
2013 VERMEER...
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A51572)
2005 Hino 268...
2018 XCMG XE210CU CRAWLER EXCAVATOR (A52576)
2018 XCMG XE210CU...
Skid steer auger plate (A50322)
Skid steer auger...
