B3030 - I pulled the trigger!
   / B3030 - I pulled the trigger!
As far as I can tell, TFORAN was asking about the Kubota B3030 factory cab model, not the non-cab model with a folding ROPS which is different. The height of the 2630 and the 3030 with FROPS should be the same since the two models are the same physical size.
I'll let others answer the question as far as compatibility of the FROPS with adding an after-market cab later on. Adding the Kubota cab at a later time is not an available option from Kubota, and the cab model is only available on the B3030.
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52128)
3-Point Hitch Root...
2014 UTILITY 53FT DRY VAN TRAILER (A51222)
2014 UTILITY 53FT...
2012 CATERPILLAR 336EL EXCAVATOR (A51242)
2012 CATERPILLAR...
1264 (A50490)
1264 (A50490)
2018 NISSAN TITAN PICKUP TRUCK (A51222)
2018 NISSAN TITAN...
2019 HINO 268 26FT BOX TRUCK (A52141)
2019 HINO 268 26FT...
