b3030 hydro oil
/ b3030 hydro oil #1
firedave19
1978 mtd 990
Is it normal for cylinders and hoses to be almost impossible to touch because they are so hot after a few hours of digging on my b3030 backhoe
/ b3030 hydro oil #2
Heat kills hydraulics dead. Seems unusual for them to get that hot but also you are using a consumer product for industrial purposes. These tractors are meant for intermittent use. I would engineer a better oil cooler.
/ b3030 hydro oil #3
Yes, they do get that hot. I have an old B2400 and a newer 4330, both HST and both with FEL's but not backhoes. When the FEL is worked hard the valve block is too hot to touch for more than a second or two. And your backhoe probably heats up the oil more than my FEL and HST together because backhoes seem to spend a large percentage of the working time against the stops; it with the pressure relief valves flowing, which really heats up the oil.
But the proper hydraulic oil will maintain sufficient viscosity to keep rubbing surfaces apart even at 100 deg C, which is whole lot hotter than it gets in the tractor. Likewise, proper hydraulic oil does not oxidize very rapidly at temperatures below 100 deg C, so the temperatures you are feeling do not significantly shorten the oil's life.
There are charts somewhere on the Internet that show how long you can touch different surfaces at various temperatures; I vaguely recall that 150 deg F metal is too hot to touch for more than a second or two. And the hot water from most hot water heaters is 140 deg F or less. Run a metal pan full of hot water from a tap near the hot water heater and feel the pan; I suspect it will be hotter than your hydraulic valve.
Better yet, buy an inexpensive infrared thermometer for an accurate reading of the valve body.
/ b3030 hydro oil
Thanks for info just first time I ever had a machine like this just was wondering
/ b3030 hydro oil #5
When you work them hard in warm weather the hydraulics on the Kubota Industrial TLB's get just as hot. In fact that's the case with about any backhoe, loader, dozer, etc etc. Just the nature of the beast, I wouldn't worry about it.
/ b3030 hydro oil #6
What Verticaltrx said is true. It sounds like your machine is working just fine.
/ b3030 hydro oil #7
An infrared thermometer will tell you the temp in a second. Do an internet search on heat and hydraulics and you will find that 140* is the top end for a sustained temp. Anything over that and the life of your components is shorted.
Case 1044 Combine Head (A65640)
Case 1044 Combine...
Skid Steer Smooth Drum Roller (A65640)
Skid Steer Smooth...
2018 John Deere 4052M (A64126)
2018 John Deere...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
2019 Ford F-150 4x4 Pickup Truck (A64556)
2019 Ford F-150...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
