B3030 - front weight for rear bush hog
   / B3030 - front weight for rear bush hog #1
cart99
Northern VA
Kubota B3030
I would really like to be able to mow and drag my fields without the FEL. How much weight do I need in the front? Are suitcase weights available for the B3030 and if so how many would I need and how much should I expect to pay?
   / B3030 - front weight for rear bush hog #2
Im sure the weights are available for the 3030, i would guess the front plate would hold 4, 50 pound weights. Last time i priced them they were running around $1. per pound, steele is gone up in price since then? I have a small rotary cutter, landpride 1542, its a small swath but i can use it without the fel and she cuts like a mad dog when i put 25 pto hp through her!
   / B3030 - front weight for rear bush hog #3
The weights for the B-series tractors are BL8060-1 (55 lbs each). Each weight also requires a BL8062 bolt kit, however my dealer just grabbed the required bolt/nut from a parts bin. The B-series tractors have room for up to 3 of these counterwieghts. You can also buy a BX8064 weight bracket for the B2630/B3030 that will allow up to five additional counterweights. The list prices are as follows: BL8060-1 - $55, BL8062 - $6, and BX8064 - $92. Ten percent off of list is pretty standard.
I put 3 weights on a B8200 (weighs 300 pounds less than a B2630) and picked up a 605 pound RFM with no problem. I would imagine three is more than enough for your needs as well.
   / B3030 - front weight for rear bush hog #4
I use a 5 foot 3pt snowblower with my B2910. I don't have a FEL and steering was a little light on hard pack snow. I added three of the 55lb suitcase weights. My dealer charged just over $200 tax incl. It made a big improvement in both handling and appearence without a loader
Thanks guys. Excellent information as always.
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2015 MACK CHU613 TRI-AXLE (A50854)
2015 MACK CHU613...
2014 Dynapac CC4200 Tandem Vibratory Roller (A51039)
2014 Dynapac...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A51039)
2017 Ford F-550...
2014 MACK CXU (PINNACLE) (A50854)
2014 MACK CXU...
2016 Ford F150 Ext. Cab Pickup Truck (A50323)
2016 Ford F150...
