B3030 - front weight for rear bush hog
   / B3030 - front weight for rear bush hog #1
cart99
Northern VA
Kubota B3030
I would really like to be able to mow and drag my fields without the FEL. How much weight do I need in the front? Are suitcase weights available for the B3030 and if so how many would I need and how much should I expect to pay?
   / B3030 - front weight for rear bush hog #2
Im sure the weights are available for the 3030, i would guess the front plate would hold 4, 50 pound weights. Last time i priced them they were running around $1. per pound, steele is gone up in price since then? I have a small rotary cutter, landpride 1542, its a small swath but i can use it without the fel and she cuts like a mad dog when i put 25 pto hp through her!
   / B3030 - front weight for rear bush hog #3
The weights for the B-series tractors are BL8060-1 (55 lbs each). Each weight also requires a BL8062 bolt kit, however my dealer just grabbed the required bolt/nut from a parts bin. The B-series tractors have room for up to 3 of these counterwieghts. You can also buy a BX8064 weight bracket for the B2630/B3030 that will allow up to five additional counterweights. The list prices are as follows: BL8060-1 - $55, BL8062 - $6, and BX8064 - $92. Ten percent off of list is pretty standard.
I put 3 weights on a B8200 (weighs 300 pounds less than a B2630) and picked up a 605 pound RFM with no problem. I would imagine three is more than enough for your needs as well.
   / B3030 - front weight for rear bush hog #4
I use a 5 foot 3pt snowblower with my B2910. I don't have a FEL and steering was a little light on hard pack snow. I added three of the 55lb suitcase weights. My dealer charged just over $200 tax incl. It made a big improvement in both handling and appearence without a loader
Thanks guys. Excellent information as always.
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
2023 MAXXD TDX Drop-N-Load Trailer with Air Ride Suspension and Tilt Deck (A51039)
2023 MAXXD TDX...
2020 John Deere 870GP Articulated Motor Grader (A49461)
2020 John Deere...
1973 CATERPILLAR 988 LOADER (A51222)
1973 CATERPILLAR...
Killbros 260 Seed Conveyor (A51039)
Killbros 260 Seed...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
