B3030 fly wheel
/ B3030 fly wheel #1
BizDoc
West Central Pennsylvania
Kubota B3030HSDC
Top of my B3030 engine there is what looks like a pump of some sort. The belt moves constantly, but the flywheel attached to the pump only runs periodically. Is this an issue of is that correctly operating ?
/ B3030 fly wheel #2
If you have air in the cab, then thats way it works. If you don't have a manual for your tractor I would be getting one.
/ B3030 fly wheel #3
Leejohn is correct.
The A/C compressor clutch is cycling on/off.
The cycling is controlled by a temp sensor on the evaporator overhead.
At least your tractor is operating correctly!
I was hoping you were not posting another "my tractor hates me" issue!
You've had too many.
Good Luck!
/ B3030 fly wheel
I thought that was correct, I just hadn't seen it in a while. I smelled something hot and that was the first suspicious thing I saw. Thank you for the replies.
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2016 FORD F-250 XL SUPER DUTY (INOPERABLE ) (A63569)
2016 FORD F-250 XL...
2020 PETERBILT 367 (A63569)
2020 PETERBILT 367...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
