B3030 fly wheel
   / B3030 fly wheel #1
BizDoc
West Central Pennsylvania
Kubota B3030HSDC
Top of my B3030 engine there is what looks like a pump of some sort. The belt moves constantly, but the flywheel attached to the pump only runs periodically. Is this an issue of is that correctly operating ?
   / B3030 fly wheel #2
If you have air in the cab, then thats way it works. If you don't have a manual for your tractor I would be getting one.
   / B3030 fly wheel #3
Leejohn is correct.
The A/C compressor clutch is cycling on/off.
The cycling is controlled by a temp sensor on the evaporator overhead.
At least your tractor is operating correctly!
I was hoping you were not posting another "my tractor hates me" issue!
You've had too many.
Good Luck!
   / B3030 fly wheel
I thought that was correct, I just hadn't seen it in a while. I smelled something hot and that was the first suspicious thing I saw. Thank you for the replies.
Case-IH 165 Puma (A50120)
Case-IH 165 Puma...
Toro Zero Turn (A50324)
Toro Zero Turn...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
2019 Dodge Journey Crossroad SUV (A50324)
2019 Dodge Journey...
2016 Nissan Murano SL AWD SUV (A50324)
2016 Nissan Murano...
