B3030 cab rear lighting kit
   / B3030 cab rear lighting kit #1
LRH
GA USA
'97 NH Boomer 1925 HST 4WD, // Kubota B3030 HSTC
When I purchased my B3030 HSDC, the dealer gave me a rear lighting kit, but it was the wrong one; a single lamp kit for the non-cab model. I have seen a few pics of the rear lights on this site and one at the dealer 2-3 years ago, but can find no photos of the kits supplied switch, and it's placement, nor any online instruction sheet with illustrations, just the kit part number and MSRP. Can anyone tell me where the switch mounts, if a bracket is supplied with the switch, and a general placement or the switch. I did see a pic of what was believed to be the harness connector under the headliner for the switch, which appeared to be larger gauge wire than the two 2 wire connectors at cab back. I really only wanted the kit to obtain a factory appearance for the switch, bracket, and wiring, and was going to give the lamps to friends with golf carts to get rid of cheap foglamps they are currently using. Any info would be appreciated, pictures, or the instructions download would be nice, but just any knowledge or experience would be fine. thanks............
EDIT: The rear wiper install post by Ductape has a few good shots of the cab interior, minus headliner, and was/is a good source of information.
Bump
Does anyone on this site have a B3030 HSDC, HSDCC with a rear lighting kit, either dealer, factory?, or owner installed?
   / B3030 cab rear lighting kit #3
Sorry, I saw this post the other day and then I forgot about it. I just took a quick picture but it was pitch black outside.
The switch mounts on a plate on the upper right rear (as sitting in the seat) by the cab window. One switch is the rear work lights and the other is the rear washer/wiper. I have all cab options on my B3030hsdcc so let me know if you have any other questions.
Let me know if you need more pictures. I will try to get some more during daylight hours next time :)
Thanks a lot, that photo helps, and has good detail even though taken in the dark. My tractor has the bracket @ top of rear window, but has 2 empty slots due to neither rear lights, rear defog, & rear wiper/washer.
   / B3030 cab rear lighting kit #5
LRH, i plan on adding rear worklights to my 3030 before the snow flies. I consider both kits (wiper and worklights) to be plenty affordable. I did a blow-by-blow thread a ways back when i installed the wiper kit which was a very straight forward install. If i get the light kit before you do your install, i'll be happy to take pics of the install.
Your post on the rear wiper install was helpful, as I would have removed the headliner at some point just to see how the HVAC and extra wiring is laid out. I have learned a lot over the years by taking something apart just to see how it was/is built. From your photo; and the photo posted by amigauser I figure that the the harness you show is the harness for the rear lamps. I thought the rear wiper switch is mounted by the washer reservoir, but that may be the rear defrost, or maybe either one will fit in either position. Well anyway, thanks to all who have given info, and to those who posted pictures.
   / B3030 cab rear lighting kit #7
You will find both harnesses (wiper and worklights) taped up in the right rear corner of the cab. Drop the headliner, pull the harness down and plug in the switch from Kubota (after you clip it into its hole). If i were smart, i would have pulled the worklight harness down and left it hanging when i did the wiper install. It would have saved me from having to drop the back of the headliner again :(. The job is a little quicker if you don't have the radio to remove, but its definitely an install you can do yourself. No need for a trip back to the dealer.
P.S. I think the wiper kit was under $150........ might be worth thinking about doing both installs at the same time. I wasn't thinking far enough ahead........ i'll definitely want the rear worklights before snowblowing season hits!
   / B3030 cab rear lighting kit #8
The rear defroster control is mounted near the washer reservoir. I think the upper plate is just for the rear work lights and rear washer/wiper switches.
Thanks....
   / B3030 cab rear lighting kit #10
Thanks both to Ductape and LHR. Dropping the headliner was a cinch once I found out how to take those plastic rivets out. By the way, I had already put a lighter for a power source in that plug on the left side to run my sprayer. Fortunately, I put a toggle switch on it so, when a found a little magnetic mount light yesterday at Harbot Frieght it plugs right in so now I have a nice cab light for $2.99.
Agway Bale Accumulator (A50515)
Agway Bale...
20ft Anderson Trailer 14K (A52128)
20ft Anderson...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A52128)
2017 Ram 5500...
Year: 2013 Make: Ford Model: Flex Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 175,101 Plate: (A50324)
Year: 2013 Make...
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
