B3030 cab heat/defrost fan wont work below 32 degrees
   / B3030 cab heat/defrost fan wont work below 32 degrees #1
Michford
Michigan
Kubota B2650HSDC, 1955 Ford 860 with Sherman Napco 4WD, 1958 Ford 841 with Elenco 4WD, 1959 Ford 641
The fan in the cab of my B3030 for the heat and defrost does not work when the outside temperature is below freezing. The fan worked fine last winter. I also notice the radio goes out when I turn on the heater fan which is odd as they should be on their own fuse. Anyone ever see anything like this? Is the fan located above the headliner? I looked on Messicks at the cab parts diagram and did not see where the fan is.
   / B3030 cab heat/defrost fan wont work below 32 degrees #2
I would check the ground for the cab electrical system. There should be a ground wire running from the cab to the rest of the tractor. It is needed because most cabs have rubber bushings on the mounts. If the ground has become rusty underneath or the bolt is a little loose, then it will cause an intermittent problem.
   / B3030 cab heat/defrost fan wont work below 32 degrees #3
does it work again when it warms up?
If so sounds to me like it could have gotten moisture around it.
   / B3030 cab heat/defrost fan wont work below 32 degrees #4
Not sure,but I believe the headliner will need to be removed to remove the roof,giving access to the HVAC unit.
Others will know for sure.
Good Luck!
   / B3030 cab heat/defrost fan wont work below 32 degrees #5
This is the most common culprit with "weird" electrical issues
   / B3030 cab heat/defrost fan wont work below 32 degrees #6
Thanks all for the suggestions. Temps got above freezing today, no fan. I will search for a ground wire for the cab to the tractor chassis, but there is not alot of room to search under the cab. Maybe I'll run a new ground wire if I cant locate the factory one. Dropping the headliner and pulling cab roof will be a spring or summer project to go deeper into the fan assembly.
UNKNOWN  500BBL WHEELED FRAC TANK (A58216)
UNKNOWN 500BBL...
CUMMINS 230 KW GENERATOR (A58375)
CUMMINS 230 KW...
2155 (A58376)
2155 (A58376)
2011 ORTEQ TANK MANIFOLD (A58216)
2011 ORTEQ TANK...
2002-2004 CAT 325C Excavator (A59213)
2002-2004 CAT 325C...
BOX OF INDUSTRIAL SHUT-OFF VALVES (A58376)
BOX OF INDUSTRIAL...
