B3030 blowing fuse for OPC
   / B3030 blowing fuse for OPC #1
Papoonick
Merritt island
Kubota B3030
I have a Kubota B3030. I live on 3 acres and wouldn't want to be without it. I bought the tractor new but if I had to do it over again I would have bought one that is a little bigger & more powerful. I have had it for 8 years and it has been very dependable. The minor issues I have had I have been able to take care of myself. Right now I am having an issue with blowing the 5 amp fuse for the OPC system. Both seat switches check out OK. I have removed the HST pedal switch and I think that is where my problem is. Does anyone know how to check the switch?
   / B3030 blowing fuse for OPC #2
Welcome to TractorByNet!
I moved your thread to the Kubota Owning & Operating forum. :)
   / B3030 blowing fuse for OPC #3
I had the same problem with my b2630, it wasn't the switch it is in the OPC..A new OPC is $100 plus dollars
so I just jumpered it at the switch and this cured it...I put a jumper on the wires at the plug of the switch
   / B3030 blowing fuse for OPC #4
I had a similar problem.
Problem was the neutral safety switch. Periodically the switch would short out to ground blowing the OPC fuse.
2015 International DuraStar 4300 Crew Cab Mason Dump Truck (A48081)
2015 International...
2017 Ford Explorer XLT AWD SUV (A48082)
2017 Ford Explorer...
40 Yard Roll Off Container Dumpster (A49346)
40 Yard Roll Off...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A50505)
2017 FREIGHTLINER...
2021 Bobcat CT1025 Tractor (A50490)
2021 Bobcat CT1025...
Gang Box (A50860)
Gang Box (A50860)
