B3030 Anti-Freeze Change was a Joy
   / B3030 Anti-Freeze Change was a Joy #1
AStanton
Platinum Member
North Central, CT
I have never seen such fine engineering to change the anti-freeze on a vehicle/machine as the B3030. There is a dedicated petcock that is easily accessible to drain the fluid. The overflow tank simply slides off a bracket for removal.
Well done Kubota!
   / B3030 Anti-Freeze Change was a Joy #2
Just changed my af on my 2620 and totally agree
   / B3030 Anti-Freeze Change was a Joy #3
It was easy on my JD 4010. The 4010 had the same size block drain plugs and thermostat vent plugs as the Benz 240D that we had for 25 years. It also had a nice drain cock for the radiator. The key to getting everything drained and refilled easily is that vent plug on the thermostat.
Ralph
   / B3030 Anti-Freeze Change was a Joy #4
I did mine back when I installed my block heater. I folded a piece of aluminum foil to direct the coolant from the drain into my pan. Made for a much neater job.
   / B3030 Anti-Freeze Change was a Joy #5
great idea ductape....hope I can remember that in two years when I do mine again!
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
Unused 2025 CFG MX15RX Mini Excavator (A50322)
Unused 2025 CFG...
2007 DEUTZ D 2011L03 MOTOR (A52472)
2007 DEUTZ D...
Unused 2025 CFG MX12RX Mini Excavator (A50322)
Unused 2025 CFG...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A51572)
2007 International...
Steiner VA242 Post Hole Digger (WORKS GOOD) (A50774)
Steiner VA242 Post...
