B3030 and L403 chain hooks
   / B3030 and L403 chain hooks #1
Sully2
Cincinnati, OH
Kubota B3030
Ok fellas. Newbie here so beat up on me...LOL Ive read everything I can find on chain hooks and the L403 loader (60" bucket) and even in my own mind the upper lip looks "kinda weak"??
So..from what Ive read ..welding a piece of 2 X 3 x 1/4 angle all the way across the upper lip and then welding in my 3 hooks is the way to go???
I dont intend on lifting "super loads" with the setup....most probably in the 350-450 LB class MAX and I dont need it TOO strong...but yet dont want to bend the bucket all to the dickens by NOT having it strong enough.
Am I on the right path?
BTW...The setup is GREAT!!!
Awe Cmon guys!! All the looks an not a single yeah or nay? /forums/images/graemlins/confused.gif
All I need to know is if Im on the right path or not?
   / B3030 and L403 chain hooks #3
i have a b3030 w/la403 also. i have 3 hooks welded on top with no extra bracing. if i pull/lift something real heavy, i chain off the 2 end hooks since they are braced by the side of the bucket. no problems with bending yet..............
Hmmmm! Food for thought. Much appreciated partner
   / B3030 and L403 chain hooks #5
i lift and move my 72" mmm (463 lbs) off the center hook only. i just wouldn't try pulling stumps with it.......
   / B3030 and L403 chain hooks #6
I had my bucket set up exactly as you described plus added a bolt on double sided cutting edge. I found that the added steel across the top of the bucket really makes it much stiffer, but I have not used the hooks to lift any thing. The cutting edge was added so I wouldn't wear out the bottom of the bucket. I only have 15 hours on my new B3030, but I am truly impressed with its capability. We live in a mountain community on about 3 acres of fairly steep terrain. We are building a road / driveway and many natural rock retaining walls, etc…
Dave
Clearing a wooded section of my own property is why I got this rig. Mostly leaf trash and smaller trees but there are some LARGER trees that have fallen...and if I pick one end up I can easily drag them off to the "burn pile".
The rig has more than enough power...I just need places to "hook onto"...:)
Thanks much fellas..
   / B3030 and L403 chain hooks #8
Maybe this will help. I have a 402 FEL and the hooks work very well. Im hard on the loader and the hooks are still holding fast.
I just cut 2 pcs of steel and welded to the lip.
</font><font color="blue" class="small">( Maybe this will help. I have a 402 FEL and the hooks work very well. Im hard on the loader and the hooks are still holding fast.
)</font>
Much appreciated! I did basically the same except I took the angle iron all the way across the lip. Waiting on 2 weld on hooks to arrive and with the angle all the way across I can add on anything else ( ????) I can figure on later...but dont really know what it / they might be.
The 1/4 inch thick angle iron is sooooo stiff...Im never going to bend it or the lip with anything Im ever going to be lifting.
   / B3030 and L403 chain hooks #10
Because I don't weld, I had my friend weld up a bracket on my bucket. I chose the bracket so I can change hooks or if one brakes or something. Also, I chose just the one bracket in the middle because I did not want to create an unbalanced load which could possibly spring a loader arm or tip the tractor.
PALLET OF (2) THERMOKING TRI PAC UNITS (A50854)
PALLET OF (2)...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2013 John Deere 824K (A51039)
2013 John Deere...
HEADACHE RACK (A50854)
2017 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2017 Ford F-450...
2015 MACK GU713 (A50854)
2015 MACK GU713...
