B3030 403fel 27 series front blowers.
   / B3030 403fel 27 series front blowers. #1
K
kingoflawns
Guest
Hello all, i'm aware of the ongoing problems some of you are experiencing with off center & crooked 403 fel's & kubotaone has a crooked 2782 front blower! I mounted up my 2782 today and it is straight and level as is my 403. IMHO & i am by no means a tractor authority, i really think there is a mounting issue of some kind and not a tweeked frame issue, again this is just conjecture on my part, let me provide an example. 4 years ago i purchased a 2650 front snowblower & subframe factory new for my B7500. Not only were all the threads crossed & junk because some knucklehead didin't check the tooling, the holes in the subframe to recieve the pushplates on the blower were 1/2 inch, however, the pins & pushplate holes were 3/4 inch! I think perhaps mounting plates are not identical on both sides or some hardware issue is causing this problem. As for the vibration issue some have, i don't even have a guess.
   / B3030 403fel 27 series front blowers. #2
Mr Kingoflawns. I have enjoyed your many posts and pictures of your fine machine. I have a favor to ask of you. Could you please post a picture of the blower subframe and how it attatches to the tractor? I have an old Meyers plow that I am going to mount on my B3030 and I would like to see exactly how the factory subframe is attached. I am going to make my own subframe and mount and want to make sure I do it right. Thanks.
Yes toolguy, i will take some pictures of the subframe. why don't you send me a pm with your address and i will mail you the photos, you always get more from photos in hand than you do from a monitor screen. For anyone who owns a 26 series blower, the 27 series is a complete redesign from the ground up, we will see how she performs soon.
   / B3030 403fel 27 series front blowers. #4
kingoflawns.
I removed my blower and sub-frame this weekend. I checked everything that I could to try and figure out what's not square - but I can't figure it out. Please, I don't want to scare people into thinking that all 3030's frames are bent, but in my case I do wonder.....
K1, is it possible that one of your loader stanchions is mounted higher than the other, or not identical? Tell me also, is your blower square in relation to the tractor? I measured from both sides of the tractor to the leading edge of the blower housing & it's within 1/2 inch, close enough to call square.
   / B3030 403fel 27 series front blowers. #6
The left FEL subframe mount (the upright bracket that the pin goes through) is higher than the right side, by about a 1/4 inch, maybe less. The blower appears to be square. But now I think about it, I measured out from the grill guard and the FEL mounts, if they're out, so are my measurements. Thanks for getting back to me king.
</font><font color="blue" class="small">( K1, is it possible that one of your loader stanchions is mounted higher than the other, or not identical? Tell me also, is your blower square in relation to the tractor? I measured from both sides of the tractor to the leading edge of the blower housing & it's within 1/2 inch, close enough to call square. )</font>
2015 F-550 Bucket Truck Gas Engine (A52128)
2015 F-550 Bucket...
2020 CASE CX37C EXCAVATOR (A51242)
2020 CASE CX37C...
Round Bale Feeder with Skirt (A50515)
Round Bale Feeder...
2008 New Holland B110 MFWD Loader Backhoe (A52128)
2008 New Holland...
2019 VOLVO EC350 EXCAVATOR (A51242)
2019 VOLVO EC350...
7 Shank V Ripper (A52128)
7 Shank V Ripper...
