B3030 3pt Hitch Stuck In Up Position
   / B3030 3pt Hitch Stuck In Up Position #11
Stop giving it Viagra and seek medical attention!!! It should not last more then 4 hours!!!
Come on.... I had to!
   / B3030 3pt Hitch Stuck In Up Position #12
Inquiring minds want to know, so please post the resolution of this problem once you solve it.
I keep coming back to the drop rate valve. You said its open, but I suspect what you mean is the knob turns all the way and then stops. If it was actually closed...i.e., the knob turns but isn't really opening the valve...that could cause this problem. I rememer once't closing the drop rate valve for some reason which now escapes me, then forgetting to re-open it. The next time I tried to lower the 3ph I spent a good five minutes jumping up 'n down on it trying to get it to lower, before I rememered the valve was closed. Color me embarrassed.
Thanks, but it is NOT the valve. The valve works and is functioning perfectly correct.
   / B3030 3pt Hitch Stuck In Up Position #14
Is it possible to disconnect the PTO shaft and see if it will drop?
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
Corn Reel (A50514)
Corn Reel (A50514)
CHEMICAL STORAGE CONTAINMENT TANK (A50854)
CHEMICAL STORAGE...
WEATHERGUARD TOOLBOX (A50854)
WEATHERGUARD...
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
1997 EZ S/A Spool Trailer (A49461)
1997 EZ S/A Spool...
