3-Point Hitch B3030 3 pt not lifting as much as hoped...........
   / B3030 3 pt not lifting as much as hoped...........
LD1 said:
What hole is the toplink in on the tractor side?
And how does the pallet lift? Does it lift level? or does it tilt forward a little?
When at ground level it is level but as it lifts the fork ends (away from tractor) begin to be higher so load is angled back at/ tipping toward the tractor
   / B3030 3 pt not lifting as much as hoped........... #12
If you set up the 3PH so that it "tilts" the least about or remains level, will give you the most lift capacity.
As I said, Top hole for the TL on the tractor, and lengthen it as much as you can.
   / B3030 3 pt not lifting as much as hoped........... #13
Group,
I have a B3030 and am looking at a 800 lb cultipacker....it appears the B3030 will be able to lift it withouta problem..correct?
   / B3030 3 pt not lifting as much as hoped........... #14
My rear-mounted snow blower weights approximately 400lbs and my B3030 hardly breaks a sweat picking it up.
   / B3030 3 pt not lifting as much as hoped........... #15
thanks, I have a 58 inch rear tiller and I think its weight is a little over 400. I just want to make sure I can lift 800 before I make a purchase.
   / B3030 3 pt not lifting as much as hoped........... #16
My BX would lift that much. You should not have a problem.
   / B3030 3 pt not lifting as much as hoped........... #17
The 3 pt. lift capacity of the B3030HSD shows to be 2139 lbs.at the lift point and 1676 lbs. 24" behind the lift point. You will be fine with 800 lbs.
1272 (A50490)
1272 (A50490)
John Deere 4520 Tractor (A50514)
John Deere 4520...
Yale Electric Pallet Jack (A50514)
Yale Electric...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2014 STEPHENS CRUDE (A50854)
2014 STEPHENS...
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
