b3000 cab fogging...
/ b3000 cab fogging... #2
Close the fresh air. Do you have the heated windows? You might need an auxilary fan like often used in buses if you don't.
/ b3000 cab fogging... #4
Run the A/C, it will dehumidify the air even with the heat turned up.
/ b3000 cab fogging... #6
You should be fine.
E/S
/ b3000 cab fogging... #7
No-your car does the same thing in Defrost.The air passes over the heater core and the evaporator core.The cool evaporator core removes the moist air which dehumidifies the cab,then is warmed by the heater core.Sometimes it's a balancing act between enough heat and defogging as the cool evaporator core reduces the heater output.The fogging is even worse with the blower!Good Luck!
/ b3000 cab fogging... #8
Running the A/C will not hurt the HVAC system at all.
It is actually good practice to run the A/C in the winter/wet conditions to keep humidity down and it also helps to lubricate the seals in thenA/C system.
/ b3000 cab fogging... #9
Good advice..... I also set the air to 'recirculate' and run the A/C with the heat on. :thumbsup:
/ b3000 cab fogging... #11
Don't get in the cab with wet clothes.
/ b3000 cab fogging... #13
Or work up a sweat by working outside in warm clothes and getting in a warm cab and being overdressed. I learned that cleaning out my barn.
/ b3000 cab fogging... #14
I really don't mind snowblowing.
My B3030HSDC has it's own bay in the garage.I just warm it up then get in wearing shorts and slippers.
2021 Caterpillar 259D3 Compact Track Loader Skid Steer (A61572)
2021 Caterpillar...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
AGROTEC ASE1054 TOWABLE SPRAYER (A64280)
AGROTEC ASE1054...
3pt 6' Rotary Mower (A64119)
3pt 6' Rotary...
(11) 10" X 52" I-BEAMS (A64280)
(11) 10" X 52"...
