B2X20 questions
/ B2X20 questions #1
gp1200x
Red Hook, Dutchess County
The seat on the B2X20 models appears to rotate 180 when the factory backhoe is installed. If I ordered a B2920 without the factory backhoe, do I get the same exact seat arrangement (for possibly adding a backhoe later) or do they install a cheaper seat mounting mechanism?
When I looked at some B2320s with just the FEL, I didn't recall seeing a seat mechanism that allowed the seat to rotate to the rear.
Length question...what's the shortest length trailer a B2920 with the LA364 and BH65 will fit on....my 6x12 is too small..looking at 14' 5K lb tandems / brakes for about 2k. I am assuming 14' with the BH turned to the side.
Tires....I do not see any listing for Turf sizes on the 2920 or 2620 but they have to be available. I tempted to go with loaded turfs since I have no large hills and the Ags on my current AC tend to gid into the lawn and it only weights 2K lbs
/ B2X20 questions #2
I took delivery of a 2620 last Monday. I got turf tires, 33x12.5x15. I did not get them loaded. I built a rear ballast by cutting a 55 gallon drum to 23" high and filling it with nine 60 lbs bags of quick crete for a weight of about 550 lbs. When I buried the bucket in the pile I could not get the rear tires off the ground. It is my experience and opinion that many people go way over board on ballast. To keep the rear tires on the ground, the front axle is the fulcrum. The distance from the center of the front axle to the center of the bucket is 4 feet. The distance from the center of the front axle to the three point hitch centers is 8 feet. If you can put a 700 lbs load in the fel, that is a torque of 2800 ft-lbs. My ballast at 550 lbs at 8 feet is 4400 ft-lbs. More than enough to offset the loader.
I am buying a 16', 7k trailer tomorrow, with one brake for $1599 plus tax. My 2620 measures 13' from front edge of bucket to three point hitch ends. 14' won't make it. Hope this helps.:)
/ B2X20 questions #3
13'? Mine is 11' not counting the 3PH, which normally sticks out about a foot. However, when I store mine in the garage, I detatch the lower 3PH lift arms from the tractor (not from the side links), flip them up so they are vertical to the ground, and then hold them in place with bungy cords. They only stick out about 5" when I do this. Might not seem like much of a saving, but it is enough to allow me to fully open my back door, and makes it so no one trips over and wacks their shin against the lift arms.
/ B2X20 questions
Thanks, I was hoping I could avoid the 16' length. I still need to stay with a 2" ball so that maxes the weight out at 5 or 6K (trunk hitch is rated for 5k).
I was going to load the tires since I've been told that more weight in the back helps with the backhoe. When using the FEL the backhoe will always be on so that will provide enough counterweight probably.
/ B2X20 questions
I'm assuming these lengths are with the 364 loader but I doubt there is much of a difference in the length specs between the 364 and 304.
/ B2X20 questions #6
My 2008 B2620 measures 13' from the front edge of the loader to the three point hitch:( lift point, all day long. With the rear blade, which is another 3', it is 16'. If someone tractor measures less then it is not the same tractor.
/ B2X20 questions #7
I just went in my garage and measured my B2620 again, and it is 12' from the bucket edge to the 3PH. This time I had the 3PH lift arms in the normal horizontal position.
Is your bucket on the ground? Do you have Pats and a toothbar, which combined could add almost a foot?
/ B2X20 questions #8
Hello all. Thanks for all of the great advice. Have just placed an order for the B2920 and am facing the hardest part of the process - waiting for delivery. Has anyone had any problems with the new B series? Thanks.
/ B2X20 questions #9
Bucket is on the ground, from the front edge of the bucket to the center of the three point lift point it is 13 feet. Tomorrow I will take a picture of it so you can see the tape measure. I can't see how there can be a foot difference, there has got to be a reason. I'll show you the tape and you can read it yourself.:confused:
/ B2X20 questions #10
Thanks. After I see yours, if the reason for the difference is not obvious, then I'll post pictures myself.
/ B2X20 questions #11
This should be interesting. I'm curious to see if one of you got "shorted" by Kubota. :D
/ B2X20 questions #12
I purchased a B2320 about two weeks ago and I have only had one minor problem. At 26 hours one of the FEL curl cylinders developed a pinhole leak in the weld at the top end. You couldn't even see where the leak was, but you could see the fluid shooting when you dumped the bucket fully.
It was spraying the fitting that connects to the cylinder and I tightened that up twice before I saw the spray and realized that the leak wasn't coming from the fitting.
My dealer swapped out the cylinder with one from a new loader. They said they would do a warranty return and put the new one on the loader they had in stock. It saved me from having any downtime. I've got 31 hours on the machine now and I'm very pleased with it.
/ B2X20 questions #13
I have had my B2320 for about a month and have only put 10 hours on it but I have been really happy with it so far. Mostly just using the MMM to mow tall pasture and tooling around with the loader. It has been to wet to use the box blade that I bought. It is just a little louder (vibration) than I would like but all in all I'm extremely happy. I was worried about the quality of cut from the MMM since I'm using it for my yard but the suspended deck does great. The cut looks even better than my JD 48 inch rider. One note, be sure to keep the front screen clean. I was mowing tall weeds and noticed my temp starting to climb reasonably fast. Got off and checked the radiator and the radiator screen and both were pretty clean. I took my hand across the screen on the hood and made one swipe acrossed it and instantly noticed my temp go down. Brushed the rest of the screen off with my hand and temp was back down to normal almost instantly. You can really fell it sucking the air through the screen. So far, very happy and would purchase again without thought.
/ B2X20 questions #14
My only issue is a vibrating muffler manifold once the engine gets warm. Pushing on it prevents the vibration noise. Dealer suppose to fix when in the area...
/ B2X20 questions #15
Based on the weight differences in the owner's manual for my loader, I would not be surprised if the only difference between the two is the hydraulic cylinders and the bucket. Makes me wonder if the capacity difference between my LA304 loader and the LA364 is based on the cylinders. They may use the same mounts, boom, etc.
/ B2X20 questions #16
I expect that the statement above is quite true. Larger hydraulic cylinders with a touch longer stroke. Notice that the LA364 loader is a bit slower since it takes longer to fill those larger cylinders.
/ B2X20 questions #18
There are no other bucket options available that I am aware of. ATI, or some other after market supplier may have one in the future, but the loader arm spacing is different than the B7x10 series it replaces, and I doubt they have anything yet.
Wolverine Quick Attach Tiller (A66285)
Wolverine Quick...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
2016 GENERAC MMG025IF4-01 MOBILE POWER (A59914)
2016 GENERAC...
2011 Ford F-150 Pickup Truck (A64194)
2011 Ford F-150...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
John Deere 620 Quick Attach Loader with Bucket (A65640)
John Deere 620...
