B2920 with 2 bottom plow.
   / B2920 with 2 bottom plow. #1
fredhargis
Wapakoneta Ohio
Kubota B2920, Kioto CK3510HB
I'd like a plow to use occasionally for the small garden I have, put in a food plot, and random lawn renovation. My owner's manual suggests a 1 bottom (14") plow, but the only used ones that show up around me are for much smaller tractors, many along the lawn tractor category. I do see quite a few 2 bottom plows (usually 12") show up for good prices. Will this tractor handle that OK?
   / B2920 with 2 bottom plow. #2
Some folks say that 20 HP per bottom is necessary. The other factors are soil type, tire type, 4WD, and so forth so the question about handling a two bottom plow is hard to answer.
You could always convert a two bottom to a one bottom if it doesn't work out.
   / B2920 with 2 bottom plow. #3
I've got a B2630, R-4's (not loaded) and a loader on the front. I've got a Ferguson single bottom plow which has the extra deep 16" bottom. It pulls nicely for me in soil which is on the sandy side. I'm plowing about 8" deep, and I have to use the diff. lock occasionally. I've wondered myself about pulling a 2 bottom 12" plow. I think I'll be happier plowing deeper when I'm turning over my winter rye. These small Kubotas don't lack for power - it's the weight of the tractor that is the biggest issue.
There is a YouTube video of somebody pulling a 2 bottom with a New Holland about your size. He does okay, but it looks like he's working pretty good. A bunch videos of a kid with a larger kubota, but the plow isn't set up very good. He doesn't really have both bottoms in the ground properly - just the front one.
   / B2920 with 2 bottom plow. #4
Exactly.:thumbsup:
Thanks, guys. I had thought about buying a 2-bottom, and converting it. Maybe that's the path I'll take.
   / B2920 with 2 bottom plow. #6
You'll never know till you try. Fill the bucket with rocks.:D
   / B2920 with 2 bottom plow. #7
If it's any help to you, my 2800/3400 manual says I can use either a 2 x 12 or a 1 x 16 plow. Your hp is the same or better than a 2800, so you should be ok. Tough ground may be another story however.
Sean
2014 Audi A4 Sedan (A48082)
2014 Audi A4 Sedan...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
2023 Chevrolet Tahoe FL SUV (A48082)
2023 Chevrolet...
2022 Club Car...
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
2018 Ford Explorer AWD SUV (A48082)
2018 Ford Explorer...
