B2920 with 2 bottom plow.
   / B2920 with 2 bottom plow. #1
fredhargis
Wapakoneta Ohio
Kubota B2920, Kioto CK3510HB
I'd like a plow to use occasionally for the small garden I have, put in a food plot, and random lawn renovation. My owner's manual suggests a 1 bottom (14") plow, but the only used ones that show up around me are for much smaller tractors, many along the lawn tractor category. I do see quite a few 2 bottom plows (usually 12") show up for good prices. Will this tractor handle that OK?
   / B2920 with 2 bottom plow. #2
Some folks say that 20 HP per bottom is necessary. The other factors are soil type, tire type, 4WD, and so forth so the question about handling a two bottom plow is hard to answer.
You could always convert a two bottom to a one bottom if it doesn't work out.
   / B2920 with 2 bottom plow. #3
I've got a B2630, R-4's (not loaded) and a loader on the front. I've got a Ferguson single bottom plow which has the extra deep 16" bottom. It pulls nicely for me in soil which is on the sandy side. I'm plowing about 8" deep, and I have to use the diff. lock occasionally. I've wondered myself about pulling a 2 bottom 12" plow. I think I'll be happier plowing deeper when I'm turning over my winter rye. These small Kubotas don't lack for power - it's the weight of the tractor that is the biggest issue.
There is a YouTube video of somebody pulling a 2 bottom with a New Holland about your size. He does okay, but it looks like he's working pretty good. A bunch videos of a kid with a larger kubota, but the plow isn't set up very good. He doesn't really have both bottoms in the ground properly - just the front one.
   / B2920 with 2 bottom plow. #4
Exactly.:thumbsup:
Thanks, guys. I had thought about buying a 2-bottom, and converting it. Maybe that's the path I'll take.
   / B2920 with 2 bottom plow. #6
You'll never know till you try. Fill the bucket with rocks.:D
   / B2920 with 2 bottom plow. #7
If it's any help to you, my 2800/3400 manual says I can use either a 2 x 12 or a 1 x 16 plow. Your hp is the same or better than a 2800, so you should be ok. Tough ground may be another story however.
Sean
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
2008 Infiniti G35 Sedan (A48082)
2008 Infiniti G35...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
John Deere 4655 Tractor (A50860)
John Deere 4655...
JOHN DEERE 5205 TRACTOR (A51406)
JOHN DEERE 5205...
