B2920 What size impliments?
   / B2920 What size impliments? #1
iplumb
Mason MI.
B2920
What size impliments is a 2920 rated to run? Are there different catigories? Anything to look for if buying used? Thanks
   / B2920 What size impliments? #2
I don't know about rated.In reality,You would be fine with a 6' rear blade,5' box blade,5' bush hog,6' landscape rake,6' rear mower,5' snowblower.Did I miss any popular implements?
   / B2920 What size impliments? #3
I got a 50 inch reversing tiller. Very nice if you guarden. I also got a 50 inch blade and 5 ft bushhog.
Usually it's by horsepower, so you want to look at what the implements are rated at and pick something that can be run by a 20-30hp rating.
I like this website.
Land Pride
Larry
   / B2920 What size impliments? #4
I just bought a B2620 (the same tractor as 2920 except for 3 hp.) In talking with the dealer, more experienced users, and advice gathered from TBN, it appears the limiting factor with most implements is size and weight. I think you could handle a 5' box blade, a 6' back blade, a 6' or 7' rake, a 48"-54" rotary cutter, and a 60" finishing mower. I don't have any experience with tillers or blowers. Your tractor and mine have the power to run bigger implements, but may struggle with lifting and handling heavier implements.
Will
   / B2920 What size impliments? #5
That sounds about right to me Will
   / B2920 What size impliments? #6
I have a 5 ' landpride rotary cutter, if I was purchasing again I would go with a 4'. My 2620 works great with everything else listed. Next item will be a box blade, keep watching for a deal for one of them.
2022 Case IH Steiger 420HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2018 John Deere 8370R MFWD Tractor (A50657)
2018 John Deere...
2018 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A51222)
2018 INTERNATIONAL...
2018 John Deere R4038 Self Propelled Sprayer, (A50657)
2018 John Deere...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
2012 Ford F-350 Omaha Crane Service Truck (A48081)
2012 Ford F-350...
