B2920 Overheated?
/ B2920 Overheated? #1
MattEffinCameron
New England
B2920
So I was running the tractor....mostly mowing (PTO RPM) for maybe 3-4 hours in ~90 degree heat yesterday. When I pulled it into the barn, and turned it off....I heard a noise continuing in the front of the tractor... Turns out the...coolant? was at hard rolling boil for about 5+ minutes, some of it leaking out onto the floor... I assume this is the tractor overheating?
Any thoughts on how big a deal this is? Did it likely happen an hour earlier and I just didnt realize that or is there some reason it would happen as I turn the tractor off?
Is it likely that it having overheated has caused some kind of other damage or can I probably just top it off with coolant and continue?
I was due for a service anyway so I will prob have my local shop take a look at it for me but I wanted to throw this out there so I can brace myself for what might be coming :)
/ B2920 Overheated? #2
It's a good practice to let the motor cool down when it hot by letting it idle 5 mins. or so. As long as there was fluid in it chances are no damage was done.
/ B2920 Overheated? #3
What he said......but......might be time to change the coolant anyway.
/ B2920 Overheated? #4
I wouldn't worry too much about it but you probably need to clean the radiator screen if you have one, and maybe also even need to clean out the radiator fins.
/ B2920 Overheated? #5
Prob had radiator screen clogged and/or radiator itself....last time i mowed large fields i had to clean the screen several times due to seed and other debris from plant material
200 GALLON NITROGEN APPLICATOR (A63290)
200 GALLON...
Bomag Roller (A63118)
FEED TANK (A63290)
FEED TANK (A63290)
2017 INTERNATIONAL LF687 DAYCAB (A63569)
2017 INTERNATIONAL...
71" X 97" T/A TRAILER FRAME (A63290)
71" X 97" T/A...
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
