Mowing B2920 Mid mount Mower What Engine RPM?
   / B2920 Mid mount Mower What Engine RPM? #11
I was told to run my 3030 wide open, I believe this is true for any lawn mower.
Haven't been real impressed with the cut. But I did try PTO speed today and it did much better! I Just worry about the 50 hr break in stated in the manual!! I'm pretty sure Kubota knows this motor better than my dealer:rolleyes:
Oh and did you guys get belt dust on your deck the first use? I assume its just the new belt breaking in?
   / B2920 Mid mount Mower What Engine RPM? #13
Prior to the 50 hour mark, I have run all my mowers at about 85 to 90 percent and after that at full throttle without any problems. A faster blade tip speed is going to result in a better cut or at least that has been my experience. To get a good cut at lower tip speed you need to cut your ground speed, so the faster the tip speed, the faster you can go. I like tractors as much as the next guy, but if I can cut down my time in the seat a little I am going to do it. I am too old to sit in the hot sun any longer than necessary. Now when I get in my cabbed tractor, I don't much care.
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
TPM 10 Piece Mini Excavator Heavy Duty Attachment Set (New/Unused) (A59225)
TPM 10 Piece Mini...
294 (A52706)
294 (A52706)
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A58018)
2020 KENWORTH T680...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
