B2920 loader interferance with subframe?
   / B2920 loader interferance with subframe? #1
ericher69
Veteran Member
Ontario Canada
2008 Kubota b2920
Does anyone know if I can mount the la364fl while not having to totally remove my front mount quick hitch for blower/blade?
Did a quick search but no immediate threads covering my query!
   / B2920 loader interferance with subframe? #3
The manual advises against doing this. When you connect the loader hoses to the FEL, the quick hitch is going to leak down and potentially jam into something. The quick hitch goes off and on quite easily so I think it's worth the extra time to remove it for FEL use. I have a little moving dolly for my quick hitch to facilitate swaps.
I should have specified...
I will remove the quick hitch (mid PTO ) part to increase ground clearance.
I was more specifically looking for interference with any bolted on parts that cannot be easily removed.
Eric
2019 Skyjack SJ1256THS 12,000LB 4x4 Rough Terrain Telehandler (A49346)
2019 Skyjack...
2012 Ford E-150 Cargo Van (A48081)
2012 Ford E-150...
2013 Chevrolet Impala 1FL Sedan (A48082)
2013 Chevrolet...
2019 PETERBILT 348 TANDEM AXLE 22FT REEFER BOX (A50505)
2019 PETERBILT 348...
2007 Toyota Tundra 4WD Pickup Truck (A50860)
2007 Toyota Tundra...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A48081)
2014 Utility...
