B2920 HST first time using 3 point hitch
   / B2920 HST first time using 3 point hitch #1
NoviceguyInCT
CT, Litchfield County
BX24 TLB & old JD 400, JD H140
I sucessfully removed my backhoe. I recently installed my three point hitch. But for some reason the 3pt hitch goes up but won't go down. Any ideas ? Any help would be appreciated.
Jim
Connecticut
   / B2920 HST first time using 3 point hitch #2
Not familiar with your particular tractor, but most have an adjustment for how fast the hitch drops. With no weight on it you might really need to open that valve so it drops.
   / B2920 HST first time using 3 point hitch #3
Check your owner's manual for the location of the above mentioned valve. On the "L" series tractors it's a knob centered under the seat.
Unfortunately I can't turn the 3 pt. adjustment knob at all. Is there a reason I can't turn this knob??? It won't budge.
   / B2920 HST first time using 3 point hitch #5
Can't turn in either direction?
   / B2920 HST first time using 3 point hitch #6
If you put the 3pt lever all the way down, go back and manually push down on the hitch and see if it goes down
   / B2920 HST first time using 3 point hitch #7
Obviously it's tightened in the full restricted position. How old is your tractor. If it's never used it could even be seized.
2014 VOLVO VNM DAY CAB (A50505)
2014 VOLVO VNM DAY...
2022 John Deere 8RX410 Track Tractor (A50657)
2022 John Deere...
2019 Ford F550 4x4 Bucket Truck with Altec AT41 Boom - 46FT Working Height and Jib Winch (A50397)
2019 Ford F550 4x4...
2018 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A50505)
2018 KENWORTH T680...
Travel Trailer (A48082)
Travel Trailer...
2005-  3412 ENGINE (A50854)
2005- 3412 ENGINE...
