B2920, 3pt Hitch and 4 Rotary Cutter Operation
   / B2920, 3pt Hitch and 4 Rotary Cutter Operation #1
Howard92
South Pittsburg, Tn
B2920 Kubota, GT275 Deere
This is my first tractor and I thought I knew how the 3pt hitch worked, but now I'm beginning to think I don't.
When I use the rotary cutter, I lift the front of the deck up with the hand control lever to almost level with the back of the deck. It seems to work fine like that except that the front of the cutter deck gradually starts lowering. The result is the front of the deck starts dragging the ground and I have to bump up the 3pt hitch with the control handle lever every couple of minutes. Is that normal? Or am I not setting the linkages up correctly initially so the cutter deck does not gradually lower on its own?
Any help is appreciated,
Howard
   / B2920, 3pt Hitch and 4 Rotary Cutter Operation #2
You could try closing the 3-pt hitch rate valve (knob under seat) once you have the position set where you want it. Or use check chains.
Since the B2920 doesn't have position control on the 3-pt, it will drift down over time.
   / B2920, 3pt Hitch and 4 Rotary Cutter Operation #3
Howard
On tractors with 3 point lift drift problems, I have used a chain from the implement lift pins to the tractor toplink bracket to restrict downward movement of the implement. Ken Sweet
Thanks for the replies. I guess I need to add a chain to keep it from drifting downward.
Thanks again for the help,
Howard
Gooseneck Trailer Hitch (A50860)
Gooseneck Trailer...
2016 Cadillac ATS Sedan (A48082)
2016 Cadillac ATS...
2004 Hyundai Santa Fe SUV (A48082)
2004 Hyundai Santa...
CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A50458)
CATERPILLAR D8T...
2000 PETERBILT 357 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2000 Ford F-350 Pickup Truck (A48081)
2000 Ford F-350...
