B2910 Replacement Battery Recommendations
/ B2910 Replacement Battery Recommendations #1
Don_Curley
La Sal, Utah
Kubota B2910 HST
My original battery is about ready to bite the dust, however, after almost 11 years of fairly severe service, I really can't complain.
Anyway, instead of just going with a standard flooded cell lead acid battery replacement, I was thinking of stepping up to an AGM type (which I have been switching to in my vehicles and a large generator). As long as I go with the right group number with the minimum or better CCA rating, does anyone see any issue with an AGM type battery in a Kubota B2910 tractor application?
/ B2910 Replacement Battery Recommendations #2
Should work just fine. Not a bad idea either!
Can't believe that battery lasted that long. I got 5 years out of mine.
Deano
/ B2910 Replacement Battery Recommendations #3
I am not sure how long the OEM batteries will last. Mine has been in tractor since I bought it in 2000. Thinking it should be replaced. With that kind of service would like to put same battery back in. But dealer is selling a Kubota battery that is not the same as the original. :(
/ B2910 Replacement Battery Recommendations #4
FWIW, mt oem battery lasted five yours.... which I figure is average. I replaced mine with an Interstate brand battery which I do NOT recommend. At the two year mark, the interste is nearly as weak as the OEM was when it was replaced. I'd actually like to put in a larger battery..... but it is really tight in front of the radiator, not sure I'll be able to get a bigger battery in there.
/ B2910 Replacement Battery Recommendations #5
I still have the 2003 original and it's still crankin'! (betcha it dies today)
While I would really like to go AGM, I am more concerned with the replacement battery dimensions and that it can still be appropriately secured with the OEM battery hold-down. Still researching this, but I may have to stick to something more conventional.
Caterpillar Lift Truck Parts and Service Manuals (A63117)
Caterpillar Lift...
2009 Ford F-450 Liftmoore 5000 2 Ton Crane Service Truck (A61573)
2009 Ford F-450...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
UNUSED INDUSTRIAS AMERICA 190-9' SCRAPE BLADE (A64280)
UNUSED INDUSTRIAS...
JOHN DEERE 437E LOG LOADER (A64276)
JOHN DEERE 437E...
2016 FREIGHTLINER CASCADIA 125 T/A DAYCAB TRACTOR TRUCK (A59912)
2016 FREIGHTLINER...
