Mowing B2910 Mid Mount Mower
/ B2910 Mid Mount Mower #1
dlockh4258
Lexington Kentucky
Kubota B2910
How much wider is the 72Inch MMM than the tires. Someone said it is very easy to attach and detach the MMM. I also read where someone said you cound drive over top of it and that seems impossible to me unless the tires are wider than the mower. For those of you who have the 72inch MMM, please explain how to attach and detach this mower.
Thanks,
/ B2910 Mid Mount Mower #2
These mower are built to withstand the weight of the front end of the tractor.You literally drive up and over the deck to attach and or remove it.
You have to raise the gauge wheels up as far as they go,place a couple of 1x blocks under the lip of the deck where the front tires will be rolling over the deck.Let the deck down(should be resting on the 1x blocks) and unhook all the linkage and P.T.O. shaft,raise the linkage back up out of the way,put a couple of blocks at the edge of the deck to help get tractor started up and over the deck,(4-W.D.)and simply back up over the deck itself.
Reverse this procedure to re-install it.Very simple,I've done it a 1,000 times with no problems.
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - Tier 2 - Irrigation Takeout (A63689)
Kubota V3600-T-E2...
1986 INTERNATIONAL 1900 FLATBED TRUCK (A63291)
1986 INTERNATIONAL...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2004 Isuzu NPR 14ft. Box Truck (A61573)
2004 Isuzu NPR...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
