B2791 Quick Hitch Mounting on B3200/B3300
   / B2791 Quick Hitch Mounting on B3200/B3300 #1
project_X
Ottawa, ON, Canada
Kubota L235DT and L225
Hi all,
I purchased a used quick hitch for my B3300. I'm interesting in the mounting of the plate that holds the pin for the rear of the mount. I have two brackets, but the pin looks to align with the bottom of the loader mount...I have found pics for just about every other arrangement...except the B3200 style frame.
My dealer was kind enough to send me the installation manual.
  • B2791 Manual.PDF
   / B2791 Quick Hitch Mounting on B3200/B3300 #3
Thanks for posting the B2791 Manual!!!
I'm looking to buy a front snowblower for a B3030 and finances dictate it will be used. Do you know if the earlier quick hitch B2761 will fit a B3030? I know the B2791 is backward compatible, but not certain if the B2761 will work. About 70% of the blowers I find for sale have the B2761 quick hitch.
Any info you can offer is greatly appreciated.
I don't know, but if I had a b2761, I would make it fit ;) the mounting is pretty simple
   / B2791 Quick Hitch Mounting on B3200/B3300 #5
If the snowblower was for me I'd go the "make it work" route, but this is for my Dad who is in his late 70's and I need to make it as simple as possible. Plus the tractor is equipped with a 72" mid mower and not certain how much of this needs to be removed to use the quick hitch.
How does the B2761 hitch mount in the back?
On my L3130 the quick hitch pins in the front and the drawbar is used to support the back of the very long quick attach. The drawbar is actually pushed inward when viewed form back of tractor.
   / B2791 Quick Hitch Mounting on B3200/B3300 #6
On my L3130 the quick hitch pins in the front and the drawbar is used to support the back of the very long quick attach. The drawbar is actually pushed inward when viewed form back of tractor and captures the rear of the quick hitch.
The b2791 would make a mid mower setup much easier.....
   / B2791 Quick Hitch Mounting on B3200/B3300 #8
Thanks for letting me know about the B2791 and Mid Mower.
   / B2791 Quick Hitch Mounting on B3200/B3300 #9
Do you need pics or do you have it figured out now? I could send some of my B3200 if you need them
   / B2791 Quick Hitch Mounting on B3200/B3300 #10
Pictures would be great. Since I'll be buying used any detailed pictures will help, so I know what parts are involved.
Thanks
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2018 Kubota...
2346 (A60432)
2346 (A60432)
CASE 586H ROUGH TERRAIN FORKLIFT (A60429)
CASE 586H ROUGH...
2017 Genie GTH-5519 (A53317)
2017 Genie...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
