B2710 3 Pt Won't Lower :(
/ B2710 3 Pt Won't Lower :( #1
M. Sullivan
S. E. Michigan
B2710 w/ 402 Loader and 72" belly mower.
B2710 3 Pt Won\'t Lower :(
Hello, been awhile since I've been on...glad to see the forum continues to do well.
Odd problem on my 2000 B2710, 260 hours. The 3 PH is stuck in the full up position....as is my 72" belly mower. Checked all linkages...nothing jambed. Lever actuating the the connection to the diff moves freely as well. No noises at any position, or when moving.
Never had a problem before.....use extensively when mowing/grading.
Searched the posts and found no similar issues.
Any help appreciated!! Thanks in advance.
/ B2710 3 Pt Won't Lower :( #2
Re: B2710 3 Pt Won\'t Lower :(
Try fully opening the knob that controls speed of 3PH down speed. Should be located in front and below tractor seat. Then adjust for proper speed when hitch starts working again.
/ B2710 3 Pt Won't Lower :( #3
Check your drop rate knob. I had a similar situation driving me nuts. Discovered that my kids like to turn knobs /forums/images/graemlins/confused.gif
It's between your legs on most tractors /forums/images/graemlins/smile.gif
Great minds from Michigan think alike /forums/images/graemlins/grin.gif
Thanks Ronjhall and RobS, much appreciated!
Sure enough, that was it. My 2 y/o was playing up there the other day and must have tweaked the control to lock position.
(1) 74"X49" TAILGATE (A64280)
(1) 74"X49"...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
2016 JOHN DEERE 655K CRAWLER LOADER (A64279)
2016 JOHN DEERE...
2017 Case CX145D (A62177)
2017 Case CX145D...
UNUSED WOLVERINE MAD-12-12D (A64281)
UNUSED WOLVERINE...
29 x 9.0 x 15 Tires with 5 Lug Wheels (A61573)
29 x 9.0 x 15...
