Grading B2710 3 pt. and R. Blade
   / B2710 3 pt. and R. Blade #13
Re: restricted range with the Woods RB72
I have the same limited range with my B2400 and RB60. These blades (RB60-RB84) seem to use the same frame for all blade lengths. So they are sized to allow for 360 degree rotation of a 84 inch blade, which makes the frame much longer than necessary for our blades. If the frame were shorter, the hitch arms would be less horizontal when the blade hit the ground, using more of their range. This might let you get a slightly sharper cutting angle on the blade, but probably not enough to make a difference. But at least you know the frame is plenty strong!
LOT OF METAL DOORS (A58374)
LOT OF METAL DOORS...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
EZ loader trailer (A56857)
EZ loader trailer...
2009 Ford F-150 Crew Cab Pickup Truck (A56858)
2009 Ford F-150...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
1990 LOAD KING BELLY DUMP (A58214)
1990 LOAD KING...
