B26TLB HYDRAULIC HOOK UP SWEEPER
/ B26TLB HYDRAULIC HOOK UP SWEEPER #1
auctioneeral
shamong,NJ
KUBOTA B26TLB
B26TLB that a want to buy a skid steer sweeper to sweep road way. But I don't know how to hook up hydraulic line from sweeper to tractor because if a use 3rd function I will have to hold button in to operator sweeper. How or what could I do to operated sweeper.
B26TLB as factory 3 rd function which just as the 2 buttons mounted on joy stick which I use for a grapple.
Would I need to install a factory rear remote which looks expensive to buy.
Any idea's. I was thinking single motor spool valve and tee it into the hydraulic coming off back of tractor for backhoe.
/ B26TLB HYDRAULIC HOOK UP SWEEPER #2
what pressure and flow does the sweeper require?
/ B26TLB HYDRAULIC HOOK UP SWEEPER #3
Motor flow requirement on a sweeper important.
The B26 3rd function has about 7gpm flow. No really motor control ability.
Implements with rotational momentum unusually need free flow back to tank on exhaust side of motor.
While factory rear remotes are an option and detent an option too no real hands free flow control.
Depending flow requirements and if you need flow control ability determines your options. Might mean pto pump, tank and motor control valve.
thanks for all replys.
Do you think the forklift broom attachment would work on removing dirt off street.
/ B26TLB HYDRAULIC HOOK UP SWEEPER #7
The forklift broom would get it done, but like using a push broom, you will need to clear the bristles and make several passes, whereas the PTO broom would get it done and clean in one pass.
Really depends on your project/situation - is this an infrequent need for a few houses/sites per year to clear the surface/pavement of debris, or are you doing commercial work where this will be used over several years, and it needs to be well cleaned quickly.
/ B26TLB HYDRAULIC HOOK UP SWEEPER #8
FWIW, my town uses rear PTO sweepers all the time to clear roads from sand in the spring.
/ B26TLB HYDRAULIC HOOK UP SWEEPER #10
I don't think you can "Tee" anywhere in an open center system. Except return to tank of course.
/ B26TLB HYDRAULIC HOOK UP SWEEPER #11
If its just to keep a button depressed, a piece of Velcro or some strap to keep it depressed but easily disengaged?
I do still agree on the rear pto broom. Hydraulic will be weaker on a tractor, and probably more expensive.
/ B26TLB HYDRAULIC HOOK UP SWEEPER #12
I'm not sure about the valve on your B26 but the W&R Long 3rd function valves on my MX5800 and L6060 are not meant for continuous duty. Both overheat if they are activated for long periods. They are meant to control cylinders and hydraulic motors for short periods.
/ B26TLB HYDRAULIC HOOK UP SWEEPER #13
I have used a sabre sickle bar on the front of my B26 and I use motor rpm for the speed of the mower and just hold the button because sometimes I need it to stop quickly.
/ B26TLB HYDRAULIC HOOK UP SWEEPER #14
Been asked before, what is the gpm requirement?
B26 has 7gpm factory 3rd function. Be low for a sweeper?
I would worry about rotational momentum of a sweeper also without a motor control valve.
/ B26TLB HYDRAULIC HOOK UP SWEEPER #15
Would appreciate a user review of your Sabre sickle bar mower as a separate post.
/ B26TLB HYDRAULIC HOOK UP SWEEPER #16
this is from when I first got mine and if you will search there are several more with lots of info. I don't use mine anymore since I got the bigger sickle bar.
2005 Mitsubishi Fuso FE84D Auto Crane 3203 PRX 1.5 Ton Crane Utility Truck (A59230)
2005 Mitsubishi...
2021 FORD F-150 STX CREW CAB TRUCK (A59823)
2021 FORD F-150...
2007 Ingersoll Rand G240 240kVA 3-Phase Towable Diesel Generator (A59228)
2007 Ingersoll...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
KUBOTA SVL75-3 SKID STEER (A60429)
KUBOTA SVL75-3...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
